  • Guests: 68
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Fullbridge CAP
gangster
Fri Jul 10 2009, 06:42PM Print
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
Hi all,
Why all you guys use soo huge capacitor on fullbridge fullwave rectified drsstc's? I mostly see some 3300uF/400V what happens if i use only for example 330uF?? (those huge caps are too expensive for me)
Fri Jul 10 2009, 07:56PM
Thats your energy storage cap. All the energy for each pulse will come from that cap. If its too small, you'll limit the performance of your DRSSTC.
gangster
Fri Jul 10 2009, 09:05PM
ok i understand does it dont mind if I use a serio-paralell combination of many smaller caps, would that be a good replacement of one big cap?
Sat Jul 11 2009, 05:50AM
You can do it, but it will never be as good as a single or a couple of large capacitors.
You will end up with a higher esr so you have less di/dt and the load spread over the bank will risc being uneven unless you stable it with resistors.
It will properly be alot of work for a mediocre result, someone back me up or shoot it down please :)
LithiumLord
Sat Jul 11 2009, 11:43AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
IIRC there was a DRSSTC even without any film caps - the only cap aside the one in the primary LC was a huge load of small lytics acting both as smoothing cap and bridge bypass.
teravolt
Sat Jul 11 2009, 03:40PM
MadsKaizer is right that the esr may be less than one large cap but that it depends on how many you have. I have done a dozen with buss work in a full wave dubler configuration. I don't think it is apropriat for monster coils but table top coils are fine and they are only a cuple of bucks ea. I have seen coils like this. The place where where you will spend the money is in silicon
gangster
Mon Jul 13 2009, 12:25PM
ok, thank you guys
audio:deviant
Thu Jul 16 2009, 10:19PM
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
im in the same boat! been trying to find some cheapy ones
what does everything think of this?
seems a bit cheap to me??
