  • Guests: 54
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
terry filter question
eniyuki
Sat Jul 04 2009, 11:14AM Print
eniyuki Registered Member #2148 Joined: Tue Jun 02 2009, 02:22AM
this may be a silly question but can i use 1.5k ohms 100w resistor as a substitute for 1k ohm 100w?
because i have these resistors.
whats the difference and effect between them?
thanks!:-)
Alexandre
Sat Jul 04 2009, 02:31PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
1.5K believe you can use in place of 1 km, not much change in output voltage ....
The difereça that 1.5k is a little bigger than 1k cheesey
Sat Jul 04 2009, 03:17PM
I think the resistor is in series... in this case you should be using a 150W resistor tongue but I think you can use it, just monitor its temp.
eniyuki
Sat Jul 04 2009, 03:28PM
yes. the one connected in series. im using 100w with built in heat sink. thanks guys
Herr Zapp
Sat Jul 04 2009, 05:48PM
eniyuki -
As far as ratings, your 1.5K Ohm /100W resistors should be fine with your 15/60 NST power supply.
You didn't describe their construction; are these conventional wire-wound, tubular ceramic core parts?
Regards,
Herr Zapp
eniyuki
Sat Jul 04 2009, 08:18PM
Herr Zapp! its been a long time.
my project is almost complete, i think about 90% im just waiting my 50pcs 942c caps to arrive then il assemble it one by one.
yes these are conventional wirewound with heat sink attached
sample pics bout my tesla
04072009568
10062009415
04072009567
14062009443
29062009528
29062009527
Sun Jul 05 2009, 12:01AM
Splendid workmanship! A labour of love! smile
Herr Zapp
Sun Jul 05 2009, 06:30AM
Eniyuki -
Very nice workmanship! Your secondary is a work of art.
When you say your resistors have an "attached heat sink", do you mean that they have an integral finned aluminum housing?
You might consider adding quite a few more air holes in the inlet plate, baffle plate, and exhaust plate of your static spark gap chamber. I think the existing holes may be too restrictive to allow the vacuum motor to provide anywhere near its full flowrate.
Have you created a layout yet for your MMC? Remember to leave adequate spacing between each capacitor (at least 10-12mm), and plenty of distance between the ends of the strings to prevent any possibility of surface tracking on whatever type of material you are mounting the capacitors on.
Hope to see your "first light" photos soon .....
Regards,
Herr Zapp
eniyuki
Sun Jul 05 2009, 02:35PM
Herr Zapp wrote ...
Eniyuki -
Regards,
Herr Zapp
Herr Zapp
thanks for the kind words. it took me a lot of time winding this secondary coil. i made a 'winder' to keep things easy.
so, back to the topic.
here is what my resistor look like:
http://www.tme.eu/katalog_pics/6/9/f/69f23f47eb52ec17a805b5d4615ccee3/ax200wr%200r1.jpg
'bout my static spark gap, yeah i dont have any idea how many/where to 'put' holes.
maybe i'll add more like you said. im afraid that when i put too many holes, it'll reduced the 'force' of air getting in to the electrodes. i'll experiment!
for my mmc, i will mount them on a poly acrylic. 1/4 in thickness. is that ok?
i dont have any layout yet because i don't have any reference, the size,design etc... so im waiting for them first but
i'll design it like in the deepfriedneon MMCs
and yes hoping for some good result
again thank you for helping me all the way up
Herr Zapp!
eniyuki
Sun Jul 05 2009, 02:43PM
Harry wrote ...
Hello Sir Harry!
yes, love.. and sparks!
thank you!:-D
