  • Guests: 50
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
MSD Ignition Coil #8251
jpsmith123
Tue Jun 23 2009, 05:03PM Print
I'm wondering, has anyone here experimented with one of these MSD ignition coils?
Link2,_Use_w/MSD_7_Series.aspx
With such low winding resistances (0.04 and 86 ohms) and an "E" type core, it seems to me this coil is potentially capable of some relatively high power through-put.
If the coil was not so expensive ($122.00 is the cheapest price I see on ebay) I would buy one right now to fool around with, but at that price, I'd like to find out some more information first, e.g., what is the material and cross sectional area of the core, the number of primary turns, and the secondary self-resonant frequency.
(I sent an email to the company asking for more information but so far I haven't received a reply).
jpsmith123
Sun Jun 28 2009, 08:34PM
Well I wasn't able to find out very much about the #8251 coil, other than that the core is comprised of "common transformer laminations", and would not be good at "high frequency". I'm told that the core cross section is 0.675" x 1.275" and it is gapped.
Apparently the laminated core could be replaced (somewhat sloppily) with a Ferroxcube ferrite UI core (U93/76/16 and I93/28/16) although this would likely also increase the inductances of the windings.
Anyway, I'm told that a different msd coil, the #8201, actually uses a ferrite U core (also gapped). With its primary resistance of 0.03 ohms, and 1 mH inductance, this coil might be a good off-the-shelf solution for a HV power supply.
It seems to me that two of these in a bipolar configuration could potentially handle 1 to 2 kw or so. The unknowns are the self resonant frequency of the secondary and the duty factor of the coil (the spec says its intended for "short duration" applications).
Sun Jun 28 2009, 08:59PM
jpsmith123 wrote ...
The secondary has no inherent resonant frequency, you could think of its self resonant frequency only with primary unconnected, between the core's magnetising inductance and secondary self-capacitance, but no power transfer can happen this way (this resonant frequency is usually very low).
The resonant frequency we are interested in is when we connect the primary to a low-impedance drive circuit such as a half-bridge. When connected directly, the resonant frequency is determined by the pri-sec leakage inductance and secondary self-capacitance. When you add an inductor in series with the primary (for the purpose of lowering output short-circuit current), the system's resonant frequency also changes.
Also, you do NOT want to drive it at the resonant frequency (or its sub-harmonics when useng square wave drive), because this can lead to destructive voltages on the secondary winding and possibly damage to the driver from high currents flowing through the primary.
Sun Jun 28 2009, 10:03PM
Establishing the time constant of the primary will demystify the optimum working PRF of an ignition coil.
In the case of your coil where R = 0R03 L = 0H001, then if we decide that 77% magnetization of the core represents the most time we want to invest in the charging phase, we find this to be a very convenient 50ms.
Moreover, I have determined by observation that the secondaries are indeed resonant in a flattish low Q way, such that as dwell time decreases with increasing engine RPM there is some compensation provided by higher OP voltage.
(fo was determined using a negative resistance oscillator to excite the secondary) Three new, unused mass market coils were investigated, and fo in each case was discovered to wander around 1kHz - an adequate match for the primary time constant.
In the three coils examined, there was a clear relationship between the time constant of the primary, and the resonant frequency of the secondary.
It is possible that my sample may be too small to mean very much, or that I have bungled something, but it makes good sense to compensate for falling spark power with increased RPM by winding a weakly self-resonant secondary.
By the way, I am conducting this little investigation because it seems to me that ignition coils are too quickly passed over as beginner's toys, and that they might provide useful amounts of rectified, smoothed, EHT if their particular properties were better understood (by me! who else would waste their time on it? smile )
speakerguy79
Sun Jun 28 2009, 10:52PM
speakerguy79 Registered Member #1460 Joined: Thu May 01 2008, 12:45AM
I have used this:
Link2,_7_Series_Ignitions.aspx
Its performance fell off drastically at 10kHz. I was running a little more than a hundred watts through it. The EMI actually caused a reset of the programmable power supply I was using, and it ended up getting 60V instead of 13.8V and made a really, really fat spark before I shut it down.
jpsmith123
Mon Jun 29 2009, 05:04AM
Dr. Kilovolt wrote ...
Well of course it does. The "secondary" is an inductor, and, as with all inductors, it has a parasitic stray capacitance; thus it has a resonant frequency. Of course the purpose of measuring the SRF is to get an idea of the distributed capacitance, Cd, for modeling and design purposes.
wrote ...
Well what did you think I was referring to?
Wow that's an expensive coil! Anyway, given the low winding resistances, it seems that coil might handle some power if driven properly.
Can I ask, what kind of drive circuit were you using?
speakerguy79 wrote ...
I have used this:
Mon Jun 29 2009, 10:28AM
OK, you are right, I didn't think of measuring the capacitance this way.
I just wanted to say that the resonant frequency is not a constant and depends on how you drive the transformer, that's all.
Tue Jun 30 2009, 11:54AM
Just a quick note, I've been using normal ignition coils for eht for many years,
ignition coils are rugged and can give quite a lot of power BUT
they operate best around 1 kHz, just where hearing is sensitive.
So ignition coils are great when you want to hear the inverter - very bad if not.
Mates
Tue Jun 30 2009, 01:01PM
I played a lot with ignition coils and they can be pushed to transfer many hundreds of watts at 50KV. My experience is strictly empirical, but it seems there are kind of resonant peaks within 1 KHz-3 KHz where the efficiency seems to be the best. On the pictures below is my single iggy (made in 1974) running at 3 Khz powering SGTC. It is definitely not toy Harry ;)
1246366910 1025 FT71919 New Primary
1246366910 1025 FT71919 Coil
Tue Jun 30 2009, 01:14PM
Mates wrote ...
I would be surprised if they handled that continuously, for short runs - all right. I can also push a kilowatt through a television transformer under a minute.
If you want to test the reliability, you should leave it on at least an hour at full power. If it doesn't burn up, you can conclude the smoke test OK :)
