  • Guests: 65
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Big DRSSTC
teslacoolguy
Mon Jun 22 2009, 06:26AM Print
HI all, im back! I have been busy for the past couple months doing schoolwork and getting other things done. Im back with a big DRSSTC build.
The specs are:
Bridge, full bridge of CM300DY-24H igbt's
Primary, 6 turns of 5/8" soft copper tubing
Secondary, 12"x48" wound with #24 double build
mmc, .6uf 9kvp (good for 1500A)
Lots more info to come as it goes along but so far it's going very good and today i tested the bridge with some test GE caps that blew out very quickly of course but was quite amusing to watch wink Here are a load of pics as i constructed the bridge.
I will be adding more pics and info as i go but any feedback, questions or comments are welcome.
Robert2
Mon Jun 22 2009, 07:07AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Helo ! Very profesional bridge ! You use green wire ? :P Why you dont use deathtime ( i see only one GDT ) ?
Bennem
Mon Jun 22 2009, 05:08PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi John,
Its looking good so far!!
Where did you get your Bus caps from in the end?
i'm still looking for a couple of thoughs caps at a reasonable price...if there is such thing!....lol
Mel
Coronafix
Mon Jun 22 2009, 08:50PM
Very nice!!
Just a question about your GDT though, do you think the off centre approach is a good idea? Would this create problems with the extra inductance on one leg of the bridge? The wires look a little long on one side to me.
Great work though, it's going to be a monster kick ass coil!!
tesla500
Tue Jun 23 2009, 01:40AM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
Great Bridge! Are you running voltage doubled 240V, or just rectified?
Some suggestions:
You may have problems driving large IGBTs with a GDT like you're using. I'd suggest making two GDTs, or at least have two Cat5 cables around one core. Then use two pairs for each individual IGBT. The two IGBTs in each half bridge must be driven by one Cat5 cable to keep the windings coupled properly. Also, a larger core area and less turns is preferable to keep inductance down.
It's also critical to keep the leakage inductance between windings to a minimum to prevent shoot-through. To do that, cut all the GDT primaries as close to the transformer as possible, and connect all 4 windings directly in parallel at that point. Then from that run 4 parallel twisted pairs to your driver board. So in total, you'll have 8 pairs going from your driver board to the GDTs.
As Coronafix said, the GDT wires should all be the same length to ensure balance.
For your current sense transformers, you can use just one core around the bridge output wire, then run the secondary of that through all the 2nd stage transformers. Since it's current fed you can do this without problem.
If I haven't explained anything well enough, please let me know and I'll try to do a better job.
David
Tue Jun 23 2009, 06:03AM
Great work
Nice to see that high power coils are being built!
Cheers, Finn Hammer
teslacoolguy
Mon Jun 29 2009, 08:38PM
Hey guys, thanks for the kind comments. I got some more work done with the coil. The CDE capacitors came so i built the MMC and started doing some real power tests.
Here is a picture of my setup right now Link2
Right now i have not pushed more then 620Ap through it because i am running on 120vac(350vdc) on the bridge. Here is the primary current waveform Link2
Coronafix
Mon Jun 29 2009, 10:03PM
Nice work TCG!! Looks really good!
