  • Guests: 36
Best place for ZVS Torroid cores?
Killa-X
Sun Jun 21 2009, 10:16PM Print
I was trying to figure out what size core i need to make a ZVS driver. I know if it's too small, i risk overheating. So I wanted to make sure I get the right core.
I was going to get a few things at electronic goldmine, and figured I might as well get a core there (if any are good) but I believe they're too small. Need a torroid core. Where do you guys often buy yours at?
Robert2
Sun Jun 21 2009, 10:44PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Small 56uH Toroid, all ferrite core from ATX power supply are goods.
Myke
Sun Jun 21 2009, 11:58PM
People usually use the yellow/white cores from ATX power supplies because the cores can be run with a DC current though the windings. Other people have used ferrite for cores but I don't know exactly how well that works out.
KLH
Mon Jun 22 2009, 03:50PM
The ZVS driver inductor needs to store energy. Therefore, by definition, there must be an air gap in the inductor's core so that it can store energy. This means that you CANNOT use pure ferrite cores without an air gap.
For low losses, especially in a ZVS driver, I recommend that you use a gapped E core, since the ferrite material provides lower core losses at higher frequencies. However, since these are relatively hard to find, you can also make the inductor using an iron powder core. I recommend the red #2 material instead of the yellow-and-white #26 material, because it has much better DC saturation and high frequency characteristics. The lower permeability of the #2 material means you will have to use more turns for a given inductance, but this is usually easily compensated for by using larger or paralleled wires.
You can easily order these kinds of cores from Amidon.
Mon Jun 22 2009, 04:09PM
You definately can use ferrite cores. I dont know why but I think their huge inductance makes them run at the "verge" of saturation while the current ripple is not that high because of the large inductance. For my first driver I used an ungapped core and adding a gap didn't make any difference.
Tue Jun 23 2009, 05:38AM
A zvs inverter needs TWO cores,
A) one for the resonant transformer
B) one for the dc link inductor
Which cores you use depends upon the intended frequency (core material)
and power level (core size)
For initial experiments I reccommend that for the dc link inductor you use
an air-core inductor that will not saturate, e.g. a roll/reel of copper wire
(mains wire, speaker wire, interconnect wire .... anything like that)
This will allow you to 'test' your resonant transformer core
without also testing the dc link core, one problem at a time.
Once your zvs is working well then experiment with the dc link inductor.
Material #2 is an old favourite of radio hams (I prefer #6, #7)
Unless you're going to operate well above 100 kHz these materials are not required.
Iron powder cores are good but ferrite with an airgap is better (I think)
If you can't find gapped ferrite try a ferrite aerial rod (for the dc link inductor too)
KLH
Tue Jun 23 2009, 04:11PM
Sulaiman wrote ...
Ferrite cores with discrete airgaps are better than iron powder cores at higher frequencies because of ferrite's inherently lower core loss. If using the core at low frequencies or with DC, iron powder cores will yield better core utilization and smaller size.
If you use aerial rods (or any significantly open magnetic circuit type) be sure not to let the flux couple between the two magnetic parts (such as using ferrite rods for both the transformer and the inductor and placing them end to end). Also, the inductance for the rod configuration is somewhat unpredictable, but to get the best quality (Q and high inductance) the winding should be centered on the rod and spread out over the whole surface of the rod.
