  • Guests: 48
Banana Man (41)
TheAnomaly (13)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Solvents for anthracene.
Sun Jun 21 2009, 01:43PM Print
The usual solvent for re-crystallizing anthracene is a mix of carbon disulphide and carbon tetrachloride, but I have neither.
But I do have the following: ethanol, methanol, isopropanol, toluene, benzene, xylene, and tetrahydrofuran. Could any combination of these produce even a small crop of tiny crystals?
MinorityCarrier
Mon Jun 22 2009, 05:37PM
My CRC handbook indicates that anthracene is slightly soluable in ethanol and benzene. Hot (watch out!) solvent may dissolve enough anthracene to recrystallize out usable quantities upon cooling to say 10C.
Bored Chemist
Mon Jun 22 2009, 07:08PM
Do you actually want tiny crystals?
I think that you could probably dissolve quite a lot of antracene in hot toluene and let it cool slowly to give nice big crystals of fairly high purity.
If you want tiny crystals dissolve the stuff in THF and add the solution to an excess of water with vigorous stirring.
Mon Jun 22 2009, 07:56PM
Thanks fellas - I'll try both, and hope the moths don't get wind of the scintillations. smile
