  • Guests: 41
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Arcing between first few turns on secondary
RichM
Mon Jun 15 2009, 07:47AM Print
RichM Registered Member #950 Joined: Sat Aug 11 2007, 02:11PM
Recently my TC started arcing between the first few turns on the secondary. It was well varnished.
There's no arc between primary and secondary at all.
Is the coupling too tight and creating more volts per turn than the insulation can handle?
It has 1kVA input and 75cm output so far.
Mon Jun 15 2009, 11:28AM
This is usually a symptom of bad grounding of the secondary. If the secondary isn't grounded properly, you can get a voltage node developing at the base (or really anywhere) which can appear anywhere.
By grounding the secondary base, you ensure that the peak voltage node occurs at the top of the coil.
lhl_henrylui
Mon Jun 15 2009, 01:01PM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
How we properly ground it?
RichM
Mon Jun 15 2009, 01:45PM
I use a large ground rod in the earth. The wire to it is thick earth wire but maybe the fac that is is quite long and coiled causes a problem. I will shorten it.
Also the contact between RF ground and the base of the secondary is made using an area of copper foil contagting eachother. Maybe this is not a good contact. I will ajust this too.
Thanks for the help.
Mon Jun 15 2009, 03:05PM
Yes, i would try that first.
Remember, if you are getting arcing at the bottom of the secondary (and none to the primary) its because you have a large voltage there, which is due to improper grounding.
Now if you have arcing to the primary as well, than it could be the coupling is too tight as another possibility. In this case, raising the secondary with respect to the primary will decrease the coupling.
Plasma Lover
Mon Jun 15 2009, 09:50PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Dr. GigaVolt wrote ...
Aren't we looking for a voltage anti-node at the topload? A node would be when the voltage is lowest, so an anti-node would be much more desirable, correct?
Tue Jun 16 2009, 01:26AM
There should be a zero node at the base where the secondary is grounded (reference point), and a peak voltage node at the topload where voltage is at its maximum. The electrical length between these nodes is 1/4 wavelength. In a half-wave coil (bipolar), you would have the center grounded (zero node) and peak voltage nodes at each end. 1/4 wavelength from the center or 1/2 wavelength from end to end.
lhl_henrylui
Thu Jul 23 2009, 08:19AM
I don't understand.Anti-node and node are the phenomenons of wave but how a tesla coil is related to wave?
Thu Jul 23 2009, 11:09AM
lhl_henrylui wrote ...
Its the electrical length of the Tesla coil and phasing with respect to each turn.
lhl_henrylui
Thu Jul 23 2009, 02:51PM
What is "electrical length"?
