  • Guests: 54
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
offer: 480 volt control transformers
Sun Jun 14 2009, 01:01AM Print
I want to get rid of some industrial control transformers (to prune my collection).
Maybe somebody here could use one to rapidly charge caps for a coilgun or something, safely isolated from utility power. $1.50 per pound + cost of postage. Photos on request.
#1: 460 V : 115 V. 60 Hz, 100 VA, 5.5 lbs. Insulation on external wires is about to crumble, but they can be replaced after opening a steel wiring enclosure..
#2: 480 V : 24 V. 60 Hz, 150 VA, 5 lbs. Screw terminal connections.
#3. 200,208,220,230,240,277,380,400,415,480 V : 24 V. 60 Hz, 50 / 105 (momentary) VA, 4 lbs. Screw terminal connections.
#2 and #3 could be used with a 120 V : 24 V transformer from the hardware store. I have a couple of those available too, 40 VA size with prongs to plug into wall outlet. 1.5 lbs.
rp181
Sun Jun 14 2009, 01:20AM
interested in 400v, # 3. Can i have a pic and estimated shipping to Colorado springs?
Also #2.
Sun Jun 14 2009, 10:34PM
$10.25 for USPS medium flat-rate box. Could hold 1, maybe 2 of these transformers.
Here are some pictures (it's much easier to put them here, than to edit them into original post).
1245018710 2099 FT71417 3 Trans
1245018710 2099 FT71417 Trans2
1245018710 2099 FT71417 Trans3
1245018710 2099 FT71417 Trans3b
