  • Guests: 38
RoV IW3IPD (63)
01/13 si2030 (62)
got an idea on how to connect marxes?
Self Defenestrate
Tue Apr 11 2006, 12:00AM
Good work on the Marx there, Teravolt! Acrylic isn't much fin to machine, and it looks like a good job. I too would agree with going bipolar, it makes things a bit easier to store too. Mike, when you changed out the VR68 resistors for the carbon comp type, did you use the same setup, strings of 3, or were they different value resistors?
Omicron
Tue Apr 11 2006, 01:04AM
Very nice! I want to see more Pics. when useing it you might want to have something like 1/2 inch plexiglas to protect you.
teravolt
Tue Apr 11 2006, 05:59AM
Thanks Steve I ment that I will use a pos and neg dubler fed buy flybacks. For the resitors I used some 1953 carbon comp 750k*2 for each stage that I won in ebay. I think that I could have made them a little taller because they flashed down the colum when I opened the gaps to far. thanks for the input N.B.
