  • Guests: 43
Secondary Coil Form
ScotchTapeLord
Tue Jun 09 2009, 05:45PM Print
I am still working on gathering materials for my DRSSTC, and I have found that I have enough 30 AWG wire to construct a 6-inch diameter secondary about two feet high. I purchased a piece of acrylic tubing off ebay that fit those dimensions, but it is not perfectly circular... it is a bit squished, actually.
I happened to find some PVC the other day that happened to have 6" diameter, and it was of sufficient height, as well. Its walls were a bit thick, though.
So what am I better off using, the somewhat flattened acrylic, or the PVC? Or am I better off buying another piece of acrylic? I am *shooting for* optimum performance.
Tue Jun 09 2009, 06:05PM
Doesn't have to be perfectly circular. In fact, it could be square if you wanted it.
Just use the acrylic. You already have that.
Also, whether you use a cardboard, pvc, acrylic, or paper secondary, you really aren't going to see any difference in performance as the losses in the secondary are practically negligible compared to heating elsewhere, especially in your primary circuit.
ScotchTapeLord
Tue Jun 09 2009, 07:29PM
Okay, thanks. I hope the shape of the secondary doesn't make it difficult to wind, though.
rp181
Tue Jun 09 2009, 08:31PM
Round forms are used because there are not sharp corners, that it could corona on.
Tue Jun 09 2009, 09:22PM
rp181 wrote ...
Yes, that is a good point, but it has been done several times before.
I forget who it was, but they made a Tesla coil complete with a square primary, square secondary and even square (cube) toroid, and it worked pretty well.
Myke
Tue Jun 09 2009, 11:09PM
There wouldn't be too much corona on a square sec because the multiple windings would make the field strength not change that quickly. It would be as if the entire sec were one piece of metal (almost). What causes corona is when there is a field that changes quickly (like at the end of a needle). Is this right?
Wed Jun 10 2009, 12:22AM
Myke wrote ...
Corona is the formation of plasma around a point of high potential gradient. The higher the curvature of the electrode - as in a needle point - the higher the potential gradient for the generation of plasma. Because of the large mass difference between electrons and positive ions, the behaviour of negative and positive coronas (i.e. where the needle point is positive or negative) are radically different. For example, the positive corona is rich in ultra-violet, while the negative corona is not.
Wed Jun 10 2009, 11:32AM
Obviously a square secondary is far from optimum, however, the person who did this was simply doing it for "novelty" reasons.
Plasma Lover
Fri Jun 12 2009, 03:13AM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Speaking of square secondaries, this one takes the cake, in my opinion - Link2
