  • Guests: 69
1kv Constant Current Soucre using BJT
borderline128
Mon Jun 08 2009, 04:39PM Print
borderline128 Registered Member #1531 Joined: Tue Jun 10 2008, 08:37PM
I want to build a linear constant current source that can be used at up to 1kv. I'm using this simple design:
Const Cur Src 111
My problem is I can't find BJT that goes up to 1kv. Is there a different type of transistor I can use or can I use two BJTs set to have a even voltage drop across each?
Edit: My target max current for this source is 1 amp
big5824
Mon Jun 08 2009, 04:47PM
you could probably find a 1000v mosfet, would that work for this application?
Mon Jun 08 2009, 05:14PM
You could try 2SC3998 or BU508A - 1600V horizontal output transistors - but they have very low hfe (as low as 7 or 8 with high current) and gobble up base current like billy-oh, (8A) so you'd need to take account of that with your base feed arrangements.
If it doesn't work - well - BU508 is dirt cheap! smile
Mon Jun 08 2009, 05:22PM
I still have a BU209A here. I could send it to you if it's of any real use to you.
Mon Jun 08 2009, 05:32PM
I have to say that your circuit isn't really suitable for high voltages, but if you'd like to say how much current was needed, and what the application was, we may well be able to come up with something more realistic. High voltage is what we do here! smile
Mon Jun 08 2009, 05:44PM
The design will be heavily influenced by the required output current.
At 0 volts out the power transistor must dissipate (constant current) x (supply voltage) Watts
high voltage power bjt as used in TV and monitor would be suitable
as mentioned above, the current gain will be about 10.
A separate low voltage supply would be efficient and easier to work on.
Almost any plug-pack / wall-wart could be used.
(For initial testing use the low voltage for the output also)
(When you do go 'live' put a mains rated filament lamp in series with the ac line,
you should see a brief flash as the hvdc capacitor charges up, then it should extinguish,
if you have a fault the lamp will stay on .. usually preventing a nasty BANG)
A mosfet as used in smps would also be good.
With the added benefit of negligible gate current,
allowing very low current in the high voltage resistor.
(but you need about 5 V for gate-source and about 5 V or more across the current-limit resistor
because at low currents, as a mosfet warms up the required gate-source voltage drops -
since the zener voltage is faily constant this means the output current increases,
which increases dissipation in the transistor, increasing the temperature of the transistor more
, increasing the current more . etc. etc. = Thermal Runaway.)
e.g. 330 Vdc with 330 kOhm gives about 1 mA zener current, low but ok
... 1 mA x 330 V = 330 mW .... use a 0.5W or more resistor
The correct procedure is;
Select power supply voltage and maximum constant current required,
Find a transistor that is easily available and cheap, get the datasheet for it,
Check the SOA (safe operating area) graph to ensure that the transistor is able to handle
the required current from 0V to Supply V.
The rest is straightforward.
borderline128
Mon Jun 08 2009, 07:11PM
Harry wrote ...
The application is to charge a 1kv capacitor with a constant current in order to evaluate its C versus V characteristics. I'd like to charge it at around 1 Amp. The supply voltage will be variable from 100v to 1kv.
The capacitor we will be testing will be about 1uF. Because we don't have a power supply capable of 1amp @ 1kv, I was going to use our lower current power supply to charge a source cap of 120uF to 1kv then use this to charge the smaller test cap through a linear regulator.
I've attached the LTSpice file if you wanna take a look at what Ive got so far.
borderline128
Mon Jun 08 2009, 07:12PM
]file.zip[/file]
Mon Jun 08 2009, 07:43PM
An 'easier' way to determine C vs V may be;
Store energy in an inductor and release it into the capacitor
you could switch a large inductor to get an instant single result
(e.g. 1 uF @ 1 kV = 0.5 J = 1H @ 1 A)
or switch a smaller inductor rapidly (e.g. 1000 pulses of 1 mH @ 1 A) for a 'curve'
Benefit is no hv supply required, e.g. 24 Vdc supply,
about 30 ms on-time for 1A in 1H, 30 us for 1 A in 1 mH etc.
You still need a hv transistor (I'd use igbt or mosfet) and diode and a 556 or a pic.
P.S. For accurate results you must be sure that the inductor is linear
so the 'many small pulses' is simplest.
P.S. I think a bjt with the necessary SOA would be more expensive than a mosfet or igbt.
Mon Jun 08 2009, 07:48PM
As the design stands, the base feed resistor and the zener diode would have to be of prodigious size.
