  • Guests: 80
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
FS: Tektronix 2430A Oscilloscope Probes and others
Laser Ben
Sun Jun 07 2009, 05:31PM Print
Laser Ben Registered Member #2163 Joined: Sat Jun 06 2009, 10:49PM
Hey everybody,
I am new here, I am mainly into lasers, but a friend refered me to here. Seems like a pretty cool forum! cheesey
Anyways,
I am trying to clear out before summer, and I have a bunch of stuff for sale.
Policies:
1. YOU PAY SHIPPING
2. YOU PAY Insurance if you want it
3. I make describe everything I am selling the best I can. You will recieve what is described
And here is the list...
1. Sold
2. Sold
3. Tektronix 2430A Digital Oscilloscope with GPIB Needs screen adjustment $75
3557873991 682aa97c4c
4. Sold
5. LeCroy 9400 125MHz Digital Oscilloscope 5V power supply has a problem I have a replacement supply on the way. $250
3558701836 49b650aae1
6. HP 10400A Miniature Passive Scope Probe 10x 350MHz new with all accessories including replacement tip and clips $50
3557894425 2295faae2a
7. Coherent Compass 115M-5 532nm 5mW laser SLM Long Coherence Length with 2 controllers $150
3558708438 A037d746e4
8. Tektronix P6101A 1x scope probe new $25
3557897337 5f763106b7
9. UV ND1.5 Filter ~1.5” OD $15
3557899845 1a3749c9a9
10. Coherent Fiber Coupler $30
3558714334 Aee3c19a89
11. Coherent Gold Mirror for Er: YAG but will work with any IR $15
3558715828 73089fa45c
12. 1” Diameter LAKN22 Blank $10
3558717742 334908aa0e
13. Pack of 25 Helium Neon OC mirrors 100cm x 31cm 7.75mm only sold together $50
3558718872 C41f70e628
14. Thermawave Bandpass filter passes everything below 700nm $15
3558722124 62296bd733
15. Optical Grade Silicon blanks 1” diameter 6mm thick $10
3558723530 C534bd74f6
16. Lumenis YAG laser OC mirrors several available $25
3558725734 D571cc055c
17. 500mm FL lens AR for Visible Several Available $10
3557914903 4ef3851bfb
18. 1.125” Diameter Germanium Lens for FLIR camera $25 1 Sold 3 Available
3557918013 51c4248fff
19. BBO Crystal Blanks VERY LARGE 20.06mm diameter 8.89mm thick 1 cracked $100 each
3558730192 977bb500da
20. 8mm diameter 532nm HR $10
3558730806 450eddd418
21. 532nm Wave plate from Coherent Verdi in Aluminum rotating mounts $25
3557921135 Cba9401b74
22. Large Coherent prism AR visible $20
3557922499 0d84b24e5b
23. Small Coherent Right angle prisms. Small amount of epoxy $10 each
3557923219 72dc5c0df6
24. Visible grating from spectrometer 1.5” square on adjustable mount $25
3557925161 C727b00526
25. Sold
26. Coherent Beam Riser from a Verdi Pumped Ti: Sapphire laser raises beam about 3” and rotates 90 degrees $20
27. Coherent D3 430nm Directly Doubled Diode laser system 150 meter coherence length works sometimes $1800 OBO
3558748152 E91aae6b8b
28. Sold
29. Strange Power Meter built into DMM $35
3558751844 0eec4f36be
30. Condor 24V 37.5A power supply $40
3558752556 4a31126c26
31. Small camera system with IR filter XY Adjustable mount and angle adjustable mount $30
3557942987 E52cb27fd6
32. Anamorphic Prism Pair AR 400nm-700nm $25
3557945565 48003096cd
33. OD3 Visible Attenuator for Newport detector $15
3558757928 Ebddecc775
34. Deans XT high current quick disconnect connectors 10 for $15
3557948629 434d89e887
35. Sold
36. Sold
37. TIR Luxeon Collimator 6 degree $10
3558767006 249d301f39
38. Sold
39. Dual HDTV tuner for PC PCI-E 1x brand new $40
3558769648 0b782225de
40. TI high frequency stable clock pulse generator eval board $20
3558770628 3010f723c2
41. Sold
42. Melles Griot 2-3mW HeNe lasers 05-LHP-211-375 $20
3557962885 4b33c3da23
43. Melles Griot 3-4mW HeNe lasers 05-LHP-071-211 $30
3558774746 44ddaeac98
44. Sold
45. Uniphase 1105P HeNe laser 5mW $30
3557965813 3c437fccb2
46. Dale Qty 50 511 ohm resistors precision $10
3557967793 Be4807d687
Doubl3 Helix
Sun Jun 07 2009, 07:03PM
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
I believe the site policy is you must have at least 15 posts to post in the Sale and Trade board. Your thread might get locked.
However, this is a fantastic assortment of laser gear!
Laser Ben
Sun Jun 07 2009, 07:40PM
Oh, really, I am sorry, I should read the rules better next time. I am not a scammer though, you can check my profile on Photonlexicon, I have over 1200 posts there with no problems :)
Regards,
Ben
rp181
Sun Jun 07 2009, 09:08PM
Those rules are mainly for people that join for the intention of selling things.
Andyman
Tue Jun 09 2009, 06:30PM
Where are you located? I'd like to calculate the shipping to California for some of that stuff.
