  • Guests: 56
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
Just wondering..
Philer
Sat Apr 08 2006, 04:39PM Print
Philer Registered Member #185 Joined: Thu Feb 16 2006, 07:13AM
What size of arc could you draw when you put about thousend of Lead Acit Accumulaotrs in serie. This would give you 12kVDC and some hundred Amperes.
Im not able to get thousend accumulators, this would cost me more than 8000€ and I don't have the space for it...
Well I think this would be sick.
And what happens when you put all paralell, i bet you could get over 100kA.. good source for a powerful rapid fire coilgun ^^ nah you would have to cool down the coil with liquid oxygen or something else.
Sat Apr 08 2006, 05:05PM
Probably about the same size arc if you series'd up about a thousand 12V lead acid batteries.
Marko
Sat Apr 08 2006, 05:10PM
Q:
A:
confused who made a typo here rolleyes
I think it owuld be horrid, incredibly hot arc, like ones that could appear on large power distribution lines.
It could obivously be stretched a lot, maybe meters, hopw much exactly - I doubt anyone can tell..
Sat Apr 08 2006, 05:27PM
Have you seen that video of substation HV interruptor opening and failing to extinguish the arc? That was ~100Amps... (the arc was hundred feet long IIRC)
Sat Apr 08 2006, 05:46PM
Say the batteries sag to 6v at their 300A cold cranking rating. Then 6kV at 300A is 1.8 megawatts. That's enough heat to blind you and set your clothes, exposed skin, and indeed your whole workshop on fire, and the arc would be impossible to stop unless you had a special DC air blast breaker. I think you would end up another of those human fireball statistics like our friend streamers rule.
Marko
Sat Apr 08 2006, 06:32PM
cheesey
Steve, as the title says this is just what-would-be-if topic and nobody is really going to series thousand car batteries and blow himself off.
But since it is un-doable I dont know is there any point guessing what would really happen (except saying it will be one hell of an arc)
smile
The Wumpus
Sat Apr 08 2006, 06:39PM
The Wumpus Registered Member #325 Joined: Fri Mar 17 2006, 12:42AM
Wouldn't the internal and connection resistances add up, limiting the output severely?
Marko
Sat Apr 08 2006, 06:50PM
Voltages add up also with internal resistances.
You get the same max current as one battery would give but voltages are stacking (up to tremedous level with total 1000 batteries).
Connection resistances are something relative (its not the same if you use one 1mm wire or heavy copper busbars, are batteries tightly lined or far away from each other so connections are long)) so we omit them.
Sat Apr 08 2006, 07:19PM
Since we are on the subject of ridiculous ideas, lets say we paralleled up 1 million strings of 1 million 12V 100Ah marine batteries, put it into orbit around uranus, and discharged it into jupiter's second red spot. What would happen then??
Marko
Sat Apr 08 2006, 07:33PM
Maybe its time to lock this thread as it obivously doesnt make too much sense, it is said what could be. As EVR says, you cna series milions and then ask what-would-be cheesey
