  • Guests: 66
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
FS, Semikron SCR module
Electroholic
Thu Jun 04 2009, 03:30AM Print
1x SKKT 132/16E
Dual 130A, 1600V SCR module
$20+SH
1x SKKH 72/20E
70A, 2000V Diode/SCR module,
$10+SH
Both are used, but they work.
Wavetuner
Tue Jun 30 2009, 08:34PM
Wavetuner Registered Member #1500 Joined: Sat May 24 2008, 04:38PM
Do you still Have either of these?
Electroholic
Thu Jul 02 2009, 02:52AM
yes, they are still available.
Wavetuner
Tue Jul 28 2009, 08:27AM
Hi, Been away awhile. Do you still have the SCR? I have some money coming in for a couple of network job Aug 1rst.
My problem is if I am running CW with a tube coil, how do I turn offf the SCR once it is triggered so I can use the stacato circuit? This is not an issue in doubler circuit do to off time.
Tue Jul 28 2009, 06:58PM
Wavetuner wrote ...
You do not need an SCR this big for staccato. Something rated for about 600 volts and a few amps is fine. Use the staccato circuit, staccato is not an interrupter, it turns the tube off in relation to the mains.
Electroholic
Sat Aug 01 2009, 03:49PM
Are you planning on controlling the power into the coil with an SCR?
Wavetuner
Thu Sept 10 2009, 06:21AM
No not directly. I was under the impression that the SCR is attached to the ground side of the fillaments to to ground (quad 833c) So I need a 5kw capability or more. I still don't get how the stacatto can work properly with out switching off the SCR. Hard to do with FW CW. Ideas?
Jim
Is this doable with the stacatto zero crossing???
Thu Sept 10 2009, 10:37AM
This is off-topic for the Sale And Trade forum.
