  • Guests: 44
diptrace and brother printer
Frosty90
Sat May 30 2009, 07:29AM Print
Frosty90 Registered Member #1617 Joined: Fri Aug 01 2008, 07:31AM
Has anyone ever had any problems with printing using a brother laser printer from 'diptrace'? The printer works fine and prints anything except from diptrace, where i just get a blank page always. Any one else had this problem?
Cheers,
Jesse
Killa-X
Sat May 30 2009, 07:33AM
Blank page...No error code printed on it? My schools did that due to memory but its a school. Exactly what are you trying to print here? PCB designs? Usually printers give some type of error codes (if it has a LCD) so you can figure out the issue...
I use eagles personally, and I use PDF, or If I want multi-copy, I save it as an image file, photoshop it (with CORRECT DPI) and print. I just know with our school printers, if the DPI is too high sometimes the printer freaks out and wont print. I found 600DPI to work good..
Bjørn
Sat May 30 2009, 07:52AM
Once in a while I can't print .PDF documents, if I instead print to a .XPS file I can print the .XPS fine without problems. You can try something similar and see if that helps.
