  • Guests: 51
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
TL494 flyback driver, walkthrough of design and construction
Fri May 29 2009, 11:29AM Print
Introduction
The motivation for this little project is to gain experience in designing from scrath and work out a general guide to design a TL494 driver. I want to do this because the TL494 IC is widely used but often with little to none description of how it is set up to work with variable frequency and duty cycle. Almost every man uses the IC differently when it comes to these two features which makes it hard for some of us amateurs to understand how it works.
This driver will be used with the flyback I received from Dr. Spark, to power my long forgotten and on halt 600kV marx generator :)
Goal
With simple and common tools/components, to design a flyback driver section with mosfet driver ICs to drive a external bridge board where the GDT is also located.
Variable dutycycle 0 to 45%
Variable frequency 50 to 150 kHz
Tools available
Handtools and drill
15MHz 2-channel dualtrace scope
Fluke T5-600 multimeter
Cheap chinese LCR meter
PCB board, permanent marker and FeCl3
Progress
24th may 2009
Design the TL494 section according to goals using the Texas Instruments design guide.
25th may 2009
Build breadboard prototype with TL494
Test oscillator and outputs
26th may 2009
Design PCB for driver section
27th may 2009
Etch and assemble driver section PCB
29th may 2009
Test driver section on a halfbridge
3rd june 2009
Design PCB for halfbridge section
Etch and assemble halfbridge section PCB
Todo:
Final product: TL494 flyback driver running a halfbridge section connected to a flyback transformer.
Designing the TL494 section
I wanted the driver to be able to have a variable frequency fromm 50kHz to 150kHz, so lets find out the values needed.
The output control on pin 13 is set high from the 5V reference voltage on pin 14, this makes the two output transistors work in push pull mode, which will be used to drive each their non-inverted mosfet driver ic.
For further study and experiments the output control can be tied to ground to enable single end mode, the two output transistors will be in phase and can be paralleled for a higher output driving current.
Its possible to implement features as softstart and overvoltage , -current protection with the dead time control on pin 4, I have chosen to wire this to ground which enables maximum duty cycle in the aspect this will be a modestly powered flyback for a stable, but adjustable high voltage supply.
The outputs are each connected to the positive rail through a 150R 2W pullup resistor to bring the output signal up in amplitude.
Frequency
The frequency is determined by Rt (pin 6) and Ct (pin 5) as a normal RC timing circuit.
I choose to use a 1nF capacitor, so I can calculate the resistor values and find what potentiometer is needed, I aimed to use a 10K potentiometer as I had them at hand.
the frequency in push-pull operations are f = 1/(2Rt * Ct)
Resistor value for 50kHz = (1/(50000 * (1 * 10^-9)))/2) = 10K (rounded)
Resistor value for 150kHz = (1/(150000 * (1 * 10^-9)))/2) = 3K3 (rounded)
Another reason to use 150KHz as the maximum value is that the TL494 changes the minimum deadtime period for frequencies above to insure proper switching.
So the lowest value will be a Rt = 3K3
The frequency can be lower than 50kHz without complications, so combined with a 10K potentiometer the low frequency will be = 1/((2 * 13300) * (1 * 10^-9)) ~ 38 kHz.
Duty cycle
The TL494 have two error amplifiers which I for the sake of leaving no inputs floating have paralleled.
To adjust the duty cycle I have set up the error amplifier as a voltage follower, the feedback from the opamp is tied to the - input, that way the output voltage will be just under the input voltage. With a potentiometer and a resistor I can vary the input voltage from 0,5V to 4,76V, this voltage span is enough to adjust the duty cycle from 0 to 43%. This is acceptable in respect to the design goals.
1243595898 1403 FT1630 Tl494schematic
The breadboard is populated, the tape is to hold the timing capacitor in place since it have got short legs
1243595898 1403 FT1630 Img 2266
Here we can see the output waveform without pullup resistors, it is about 38kHz at 43% duty cycle
1243595898 1403 FT1630 Img 2267
Here we can see the output waveform without pullup resistors, it is about 38kHz at 5-7% duty cycle
1243595898 1403 FT1630 Img 2269
Here we can see the output waveform without pullup resistors, it is about 150kHz at 43% duty cycle
1243595898 1403 FT1630 Img 2268
Designing a PCB takes time to get right, and it might also take a couple of etches to elimate all the errors and corrections if you have to make changes due to new ideas.
I will not go into detail with best practises for PCB design as I do not know them all, but keep supply and power traces as wide as possible and avoid sharp corners.
1243595898 1403 FT1630 Pcb
I printed out the trace layout from ExpressPCB, which do not have the option to mirror the traces, so I used a black marker to paint through the paper so I could see the connection points through the paper, then place the PCB under it and hammered marks through the paper, then I drew up the traces by hand with a black marker. Ghetto, but works :)
1243595898 1403 FT1630 Img 2261
A weak FeCl3 bath with a syringe as circulation pump
1243595898 1403 FT1630 Img 2262
Holes were drilled with a 1mm drillbit and my accu drill from work, abit heavy to hold by hand, but worked out fine, didnt even break the drillbit, I wrapped it with aluminumwarp to support it, since the drills head cant hold that small bits
1243595898 1403 FT1630 Img 2265
Complete board
1243599180 1403 FT1630 Img 2270
GDT primary waveform
1243599180 1403 FT1630 Img 2271
I found a medium sized flyback in the collection, one without screen/focus resistor network. With a 10 turn primary I was going to push its luck :)
1243599180 1403 FT1630 Img 2249
Lovely long sparks that wound ignite from 40mm distance, voltage on the IRFP460 halfbridge is around 140VDC! Such a lovely glow around the core :)
1243599180 1403 FT1630 Img 2253
We have just lost cabin pressure! Better find that life jacket under the seat and be ready for this tailspinning crashlanding!
1243599180 1403 FT1630 Img 2254
It went okay, until everybody died.
1243599180 1403 FT1630 Img 2255
Its made from components I had available, so C3 and D3 are overrated.
1244269207 1403 FT1630 Halfbridgeschematic
Nice thick traces for the current paths, again, this was done with a tusch by hand.
1244269207 1403 FT1630 Halfbridgepcb
This time I used a large candy box for the etching as the board could no longer fit my tiny etching box, also I made a stronger FeCl3 solution this time, so the etch went alot faster. Turned out almost as I wanted, there are still small spots where the acid goes through the thin tusch drawings, but alot less than earlier etches.
1244269207 1403 FT1630 Img 2274
IRFP250 MOSFETs hanging out on the southside
1244269207 1403 FT1630 Img 2275
The complete board from above
1244269207 1403 FT1630 Img 2277
Sat May 30 2009, 01:40PM
Looks good smile
The reason why everyone does manual duty cycle adjust differently on the TL494, is that it was never really meant to be run open-loop (the duty cycle is always intended to be under feedback control) so the datasheet doesn't give any guidance on how to do it.
There are two basic ways to do it: either use one of the error amps as a follower, or use a pot connected to the deadtime control pin, in the way that the datasheet shows for setting maximum duty cycle. I don't imagine that either of them is particularly accurate, just because the chip was never intended to be used this way, so the designer had no incentive to make it accurate.
Wed Jun 03 2009, 02:16PM
Steve McConner wrote ...
Looks good smile
I never got the potentiometer directly coupled to the dead time control from the reference voltage to work as "liniar" as it does through the error amplifier, on the DTC it would be a very steep logarithmic chance in duty cycle.
Sat Jun 06 2009, 06:30AM
Updated thread with:
3rd june 2009
cjk2
Sun Jun 07 2009, 04:22PM
Random comment: I bet you could use 10k or so resistors to pull up the output section of the 494 rather than those 2w resistors you are using because the input impedance of the driver chips is very high.
Not that it makes a real difference in operation, it would just make your driver a bit more efficient and dissipate less heat.
Am I right?
Thu Jun 11 2009, 04:56PM
cjk2 wrote ...
Am I right?
I used the resistors that was used in the test circuit from the datasheet, so I did not give it a deeper thought :)
On a note of the progress, the flyback is currently waiting for the epoxy I filled it with to harden, so the project is on hold for about a week
Osama Ma'mon
Sat Aug 28 2010, 09:13PM
Osama Ma'mon Registered Member #3144 Joined: Fri Aug 27 2010, 01:44PM
the problem is the capacitors change it with 220 micro farad 400 volts
and the mosfets with irfp460lc
HDF49
Tue Jun 11 2013, 08:19PM
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
Hi, I really like the look of this circuit, I'm thinking about building it with irfp260s to drive a large AC flyback of mine, when you say "modestly powered flyback" what exactly do you mean? And if would this be able to switch about 500 watts of power? I need a about 500 watts out for a CO2 laser power supply. I'm also finding it difficult to find mur1560s cheaply, and in stock, would any ultrafast diode with a voltage rating over 200v and current rating of over 15A do? Because I've found some 200v 16A 35ns recovery diodes for 43p each. Sorry to dig up an old thread but I'm very interested in this circuit, it looks simple and versatile.
Wed Jun 12 2013, 02:01PM
HDF49 wrote ...
What I meant was with a bridge voltage that does not exceed that transformers voltage/turn ratio, as you can see in the pictures the flyback broke down due to flashover at extreme high voltages.
You basicly adjust the output voltage with your input voltage and the output current with the pulse width. I see no problem for this circuit to deliver your required 500 Watt, it is more of a question which voltage and current you need and then find a transformer that is suitable.
Any diode with similar specifications will work in place of the MUR1560s.
It is a simple circuit, a TL494 driving a halfbridge and thus is very scaleable. Insert a intermediate MOSFET stage to drive large IGBTs etc.
Experimentonomen
Wed Jun 12 2013, 02:11PM
Lots of stray inductance in that DS junction between upper and lower mosfet, as a class d designer, i cringe every time i see mosfets beeing that far apart while beeing operated at 100+ kHz.
