  • Guests: 32
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Automatic Solar Powered Plant Watering System
thedatastream
Mon May 25 2009, 08:38PM Print
Nowthen,
I'm still around, just busy with two small kids, a job and tons of DIY to do. However I've finished a project that I thought I'd share.
Main details are here, but I'll give a summary for this thread.
To prevent my plants in the greenhouse from drying out due to forgetful watering, I considered building a solar powered watering system. Two years of on and off (mostly off) work have yielded the following system.
System overview
The system uses an alarm clock to signal the control box when to water. This lets me water once a day, prefereably early morning to stop the roots sitting in water all night (when absorbtion of water is supposed to be less). I butchered a cheap solar powered alarm clock from Maplin to achieve this.
A look inside the control box shows pumps on the base (top of photo) and control electronics in the lid (bottom of photo) so they dont get wet in case of a leak.
Img 3228 Small
The main system components are generic automotive windscreen washer pumps (one per plant), a 6V SLA battery, a BQ2031 battery charger evaluation board and a custome made control board built from various passives, a 555 timer and some 4000 series CMOS logic. Link to control circuit below.
Master Control Circuit Small
Solar panel was sourced from eBay and is Volkswagen branded - designed for trickle charging car batteries through the fag lighter socket. Water comes from the 200 litre water butt by the greenhouse.
This system is still to be installed, I've got that scheduled in for next weekend. I'm going to add soil moisture sensors at some point, one per plant. Possibly some solenoid valves if I have problems with siphoning.
Many more details on the website.
It's still to go through some serious testing and I'm looking forward to seeing how it performs. Watch this space for updates.
Regards all,
James
Mon May 25 2009, 10:16PM
Now that's home engineering. Interesting project for something so mundane.
Coronafix
Tue May 26 2009, 03:45AM
Nice work!! I thought of doing the same for my greenhouse but nothing so complex. I was going to use an inline timer tap to do the watering.
Well done though!
Tue May 26 2009, 09:46AM
By eck! Wallace and Gromit would be proud.
syntroniks
Tue May 26 2009, 06:11PM
syntroniks Registered Member #1530 Joined: Tue Jun 10 2008, 03:34PM
I shaped my tank out of sheet aluminum and made it look lime a cactus cheesey No solar yet though.
I only wish your project was here a few months when I started so I could learn more! Great job!!
EDIT
Looking at it again, it looks very professional, it's perfect!
Also, instead of the 555 business and logic chips, I'd consider a microcontroller and RTC. Either way, good call on the WW pumps.
thedatastream
Tue May 26 2009, 07:55PM
Cheers :)
I did consider an ATmega16 and an RTC but I'm not current on micros at the moment and the learning curve would have been too steep to enable me to get this projet completed for this years growing season. Logic and a 555 enabled me to lash it up quicker and design circuits when stuck in boring meetings.
