  • Guests: 27
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Not so airsoft gun
Maz
Mon Feb 13 2006, 01:02AM Print
Maz Registered Member #111 Joined: Fri Feb 10 2006, 01:04AM
at first when i had the idea of making an airsoft gun, it was to fend myself off from my fiendish friends. but now, it just seems like a lot of fun.
the goal: the goal of this project is to make a very powerful (400+fps) semi-auto airsoft gun that uses a regulated air source as cheap as i can possibly make it.
Planning and design: i know what i have, and i know what i want, so how do i get there. the regular gas airsoft guns use a type of gas that is not as powerful as CO2 nor is it as easily obtained. im going with CO2.
i want it semi auto, so either i would do expensive sensing(which i dont know much about) or come up with a mechanical solution. i choose mechanical. keeping it as simple as possible i come up with this design. Candeleteairsoftsemides
Building: i found my material. it is called ertalon 66SA (cast nylon polymer) http://www.bayplastics.co.uk/data%20sheets/Quadrant/ERTALON66SA.pdf i can practically machine the crap out of it and it will come back for more.
current stage: Cutting drilling templates and measuring stock.
Omicron
Thu Mar 02 2006, 02:18AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
For this sort of thing try posting here: [www.rougesci.com][/link]
You will get better advice at this sort of thing.
Michael W.
Thu Mar 02 2006, 02:31AM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
A dangerous Forum, Regardless the link is Link2
