  • Guests: 51
williamn (48)
ReddyK (57)
Birdman (31)
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
NST question
EvilTesla-RG
Thu May 14 2009, 03:12AM Print
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
I have a few experements I want to do.
But first, I need to rectify my NST.
Everything I have seen on rectifing NST's, is to put a large, expensize, Full bridge rectifier on the out put of the NST.
HOWEVER!
wouldn't it be cheaper and easier too put a full bridge rectifier on the INPUT of the NST?
I wouldn't have to deal with the 15kv. And it should work, as the amperage will still vary, it just wont go negitive.
Also, just checking to make sure I know what I am talking about: To rectify means to convert AC into "chopped" DC, Generaly VIA using Four Diodes (Full Bridge Rectifier).
Corey
Thu May 14 2009, 03:21AM
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
ummm i could be wrong but the cores used for nst are for ac only, any attempt in rectifying the input would saturate your core. your best bet would be to put a string of diodes on the secondary side. many diodes can be used to increase the voltage rating, they can be slow diodes as the output is most likely at 60hz.
-Corey
Myke
Thu May 14 2009, 03:45AM
If your NST is large-ish and the case isn't plastic then it's a 60Hz NST. For the newer high freq ones, you would need faster diodes like the UF4007. Also, as I have heard, the newer versions don't like loads that have a low voltage drop like an arc so they won't work for a tesla coil.
J. Aaron Holmes
Thu May 14 2009, 04:37AM
EvilTesla-RG wrote ...
HOWEVER!
Well sure, it'll be cheaper and easier, but it won't do what you want. You'll still just get AC out.
Check eBay for deals on diodes, then make a MMR (Multi-Mini Rectifier) wink
Cheers,
Aaron, N7OE
EvilTesla-RG
Thu May 14 2009, 04:51PM
Awsome, thanks for the info.
Thu May 14 2009, 06:40PM
J. Aaron Holmes wrote ...
And smoke your primary and the diodes too (or pop the breaker).
EvilTesla-RG
Thu May 14 2009, 06:48PM
KK,
I'll buy four 15KV diodes, and make a full bridge on the output.
hotcrazyfruit
Thu May 14 2009, 08:11PM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
to put it at its simplest,
DC doesn't transform very well >_>
just use a bunch of small series diodes... they wont be very expensive, as the only need to handle like 30 or 60 mA. a freind of mine bought 1000 , 1000volt 1a diodes for 10 bucks at mouser.
LithiumLord
Thu May 14 2009, 08:37PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Afaik SSNST works well with DC supply, although it's not what you need about the output it's still a way to feed it off a UPS or any other non-sine step-up convertor ;)
Myke
Thu May 14 2009, 10:50PM
KK,
You will need diodes with a PIV (peak inverse voltage) of higher than 15kV because 15kV is just the RMS voltage. The actual peak voltage is ~21.2kV. I would recommend using diodes with a PIV of more than 25kV just for a safety margin. Using strings of lower PIV diodes is a cheap way to make your own HV diode.
