  • Guests: 47
AC flyback or DC flyback?
haxor5354
Wed May 13 2009, 08:11PM Print
this fkyback transformer was scavenged from a welder, NOT FROM A TV. although it looks like it's from a TV
1242245487 2063 FT0  014
1242245487 2063 FT0  015
Wed May 13 2009, 08:20PM
I think it's DC. A simple test, put an isolated conductive object (a coin) near the HV output and turn in on. If it arcs to it, it's AC. If it makes just little sparks or nothing, it's DC.
Or, connect two "antiparallel" LEDs in series with the arc. If only one lights up, it's DC. If both, it's AC.
LithiumLord
Wed May 13 2009, 09:23PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Or connect a HV cap in series with the arc gap - if it charges up, it's DC - otherwise it will just arc constantly ;)
twist2b
Thu May 14 2009, 04:01AM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
anti-parallel the LED's is the easiest way to go. (IMO)
Personally I think its DC... older versions (it looks old to me) always used DC, newer versions are AC.
That is cool though. Good find! :)
