  • Guests: 72
Unknown Flyback xfmr
MOTVolt
Thu May 07 2009, 11:54AM Print
MOTVolt Registered Member #1996 Joined: Wed Feb 25 2009, 03:56AM
Does anyone know if I can just short all the pins at the bottom of an unknown flyback to the core and use that as the ground side of the HV?
Cheers :)~
wicked alex
Thu May 07 2009, 11:56AM
wicked alex Registered Member #1786 Joined: Tue Oct 28 2008, 03:23PM
No, i have tried that and it did not work good for me angry
i only had 1cm sparks (normaly 2cm).
alex
Thu May 07 2009, 06:01PM
Only ground each group of pins, which are internally connected together, at one point.
MOTVolt
Fri May 08 2009, 12:37AM
Well at least someone else has tried it! I found out how to trace the other end to the HV winding from an old post, should have searched first right! Anyway all you do is put the negative end of a >20V supoply on the HT lead, then probe the pins for the highest voltage...
