  • Guests: 39
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Various High Voltage Equipment for sale
Bamacoiler
Wed May 06 2009, 03:27PM Print
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I have a good deal of stuff I need to get rid of because of a financial problem my family is in at the moment.
I have
*1 50kva Pole Pig, 2 eared, one phase, primary:12470v, secondary:480v
*1 step up tranformer 10kva 240-480 to power up the pig
*1 allen bradley 100+amp contactor, 120v coil
*1 100lb transformer core for ballast custom machined to allow the i section to slide up or down, unwound
*2 rolls 500ft 10gauge to wind the ballast with
*4 GE 800pps older pulse capacitors from linear accelerator 28kv 0.02µf(large about 35 lbs each)
*2 1256d closed frame variac pies have a 3/4" rod for the shaft and the wheel but no dial.
would sell together or seperate.
*1 ge 240in 280 out variac rated at 30 amps open frame
* RFL 829d meter calibrator (ancient but works great and very accurate was used as our primary standard in my calibration lab some time ago)
*variacs of all types, 120vprimaries, 240v primaries just ask if interested
* various other odds and ends
I really wanted to turn this into a monster spark gap coil but I'm in really bad financial shape so it's just not going to happen.
If Interested please pm with offer and if reasonable it will probably be accepted.
Located in Northeast Al so the larger stuff will have to be local pickup but could ship the capacitors, contactor, wire etc.
Pictures upon request
Thanks for looking,
Bamacoiler
Mike
Wed May 06 2009, 04:15PM
Are you willing to ship variacs? If so what are you asking for the 240 primaries?
Bamacoiler
Wed May 06 2009, 07:23PM
I can ship the variacs. How does 100 bucks per pie sound?
1256d pie-$100 each plus shipping
Ge 30 amp unit-$100 the wheel is broken but usable
Bamacoiler
rp181
Wed May 06 2009, 08:41PM
how much for a variac 120v in, atleast 120v out? at least 10 amp, 20A prefrable.
Bamacoiler
Wed May 06 2009, 11:02PM
I have 12 amp stacos 120in 140 out for $40. I also have the 30a 240v GE that would probably be fine at 120v 50a for $100.
Bamacoiler
Tue Jul 28 2009, 02:33PM
1256d variac one pie on ebay, great deal check it out please. 240v in/280v out, 28a 7.8 kva.
item#280377924213
