  • Guests: 81
Kaizer SSTC II
Sun May 03 2009, 06:10PM Print
With a good 7 weeks or so of building and experiments the Kaizer SSTC II stands a total of 56 cm from bottom to topload!
Its uses the slightly modified driver board from my version of Wards mini sstc, audio modulator by Reaching and a fullbridge of IRFP460 mosfets.
There is a great deal of pictures and a small film in this article I wrote about it: Link2
I hope you enjoy it as much as it have brought me wide smiles and lesser than lethal ozone exposures :D
Here is a couple of teasers
1241374207 1403 FT0 Img 2070
1241374207 1403 FT0 Img 2112
Z28Fistergod
Sun May 03 2009, 06:13PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
What did that I-pod do to you?
gangster
Sun May 03 2009, 07:56PM
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
very nice work! . FETs dont explodes?
Sun May 03 2009, 08:10PM
Z28Fistergod wrote ...
It died a while back while playing music on my audio modulated flyback, it wasn't designed for high voltage transients :D
gangster wrote ...
I have only blown MOSFETs when it was a halfbridge, and that was mostly because I made some mistakes, that you can read here: Link2
the fullbridge is only passive cooled, no heating at all when running in interrupted or audio modulated mode, but in continues wave mode they get too hot to touch in a minute or two.
I get flashovers from primary to secondary before MOSFET failures it seems :)
Z28Fistergod
Sun May 03 2009, 08:39PM
MadsKaizer wrote ...
Oh, serves it right then.
Mon Aug 17 2009, 05:41PM
Here is a little teaser of the new 20 cm diameter frying pan topload I put together today.
I broke off the handles, sanded it flat and drilled a hole through each pan, simple and teflon coated!
Performance pictures/film will have to wait abit till my workdesk is clear of sensitive projects :D
1250530889 1403 FT68937 Img 2600
1250530889 1403 FT68937 Img 2601
1250530889 1403 FT68937 Img 2603
brtaman
Mon Aug 17 2009, 08:48PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Looking good madskaizer, the video you made of this coil is one of the primary reasons I opted for an SSTC project instead of a VTTC one. Congrats on a great running SSTC.
How many FETs did you sacrifice to the lightning gods? :)
I like the topload, how much did it cost, those fancy pans are quite expensive I suppose?
Mon Aug 17 2009, 09:12PM
brtaman wrote ...
I only blew FETS on this coil when it was still a halfbrigde configuration, now its fullbridge and have yet to blow. As a halfbridge I blew like 4 or 6, mostly due to too high voltages on the brigde.
I found these pans in a supermarket at only 10$/7€ a piece, so I felt it was worth it to get two
brtaman
Mon Aug 17 2009, 11:11PM
That was a very nice deal for a topload of that quality. I was always under the impression that all pots and pans were quite expensive, especially ones as nice as those.
Post up a new video after you clear your desk and get it running. ;D The coil is definitely looking good.
Coronafix
Tue Aug 18 2009, 10:33PM
I love your coil. It is sweeeet!
