  • Guests: 41
Frequency Counter Recommendations
Sat May 02 2009, 01:17AM Print
Hello! I have won $200 from my 8th grade science fair and have decided to use the money to add to my test equipment and buy a frequency counter for work on my next years project on wireless power transfer. I was hoping that some of the more experienced members among us / professional electrical engineers could give me some recommendations about what models / brands of frequency counter to search for.
Thanks in advance.
(should this be in sale and trade?)
rp181
Sat May 02 2009, 02:45AM
Cool.
BKprecision has cheap function generator's with counters, I recently (4 days ago) got this one:
That is twice your limit, but you can probably find a refurbished one for less. If you can, look for a DDS rather than a analog generator.
If you just want a counter, and no generator, here is one:
Sat May 02 2009, 04:42AM
Thanks, but both of the options are a tad out of my price range :(. I have seen cheaper counters like this one Link2 on other websites, is this one any good? If not can someone recommend a frequency counter a bit closer to my price range? (i don't need ultra precision or anything)
rp181
Sat May 02 2009, 02:40PM
That one looks fine. Why don't you get a function generator? Some have frequency counters built in. For frequency counting, I use this:
Its only up to 500khz, but any higher, my function generator is good enough.
Sat May 02 2009, 04:03PM
I have a 2.4g counter here that works, its a bit dated now but still well within spec.
any use?
also have someone's homebuilt 200M LED counter..
Sat May 02 2009, 11:46PM
The 2.4 gigahertz frequency counter sounds interesting. Do you know the part number or any of the specs?
Hazmatt_(The Underdog)
Sun May 03 2009, 08:15AM
I recommend you BUILD ONE ^^ hehehe Link2
I sincerely doubt you will need more then 50MHz capable counters from the get-go, so why not build a basic stable model to get yourself started.
Sun May 03 2009, 04:16PM
Building one looks interesting. However I need one for my current project and my parents only let me work on one project at a time angry. I think there is some kits that might be on the cheep side though...
Sun May 03 2009, 09:09PM
There is a universal counter kit available with 4XXX family chips and its a 3 digit counter. There is another kit which uses a microcontroller that is a 4 digit counter and you could use those kits with a similar timebase generator that I'm describing in the counter thread, but those will probably top out at a couple MHz.
You can buy multiple kits and link them together for more digits, but the kits do cost ~ $30 each, so it gets a bit expensive after a while.
But at least the info is available right ^^.
Sun May 03 2009, 09:48PM
A lot of it's about money and quality - you can get a budget one like mine from Thurlby Thandar costing maybe $300, which is good for 99% of practical purposes, or you can pay $3,000 for an instrument from Rohde & Schwarz with fantastic accuracy and lots of very advanced facilities.
