  • Guests: 54
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Substitute for STB16PF06 in Ward's DRSSTC driver board
Tribologist
Wed Apr 29 2009, 03:04PM Print
Tribologist Registered Member #1879 Joined: Mon Dec 22 2008, 04:11AM
What are good choices for substituting the STB16PF06 that Steve use for the driver? That transistor is obsolete.
It does not look like anything special but I though that I could be lazy and ask what people used sucsessfully.
Ulf
Mike
Wed Apr 29 2009, 05:29PM
I believe a suitable replacement would be a D2Pak P-Channel Mosfet at around 50v+ and an I of 16a or greater. That's what the original fet's specs are. The data sheet of an equivelent N channel fet can be found here for reference: Link2
I'm sure Steve probably has an exact part in mind, you'll have to wait for him to respond I think.
teslacoolguy
Wed Apr 29 2009, 05:36PM
I am running into problems myself because most P channel fets have much larger delay's then those. However, Digikey still has some stock Link2
MRacerxdl
Thu Apr 30 2009, 01:51AM
I use in a similar driver circuit the IRF540/9540 ones, and works perfectly... it sabout 100V 27A, a bit oversized for that settings but its relative cheap...
Thu Apr 30 2009, 05:25AM
Sorry, i dont have a replacement spec'd yet. Those fets were picked out from the mouser site, mostly based on price. Just watch out for gate charge, blocking voltage, and Rds and make sure those specs are comparable to the part i chose. You could also go with a higher Rds (lower current rating) and get a faster switching time typically, you should change the N-channel part accordingly too. It seems to be a fairly forgiving circuit, you dont need perfectly matched P/N pairs or anything.
teslacoolguy
Thu Apr 30 2009, 07:01PM
How about this P chan fet as a replacement Link2
Mike
Thu Apr 30 2009, 07:15PM
Hmm from the datasheet it looks okay, they only thing I notice is quite a bit higher fall time on it.. though I'm unsure if its enough to effect things.
Tribologist
Mon May 11 2009, 01:23AM
Thanks guys,
I will try Lucas reccomendation. IRF540/9540 are cheap and easy to get.
Ulf
