  • Guests: 48
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
auto-trigger?
Camel
Mon May 11 2009, 06:30AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Maybe the fact that the voltage on pin 3 is equal to the supply voltage is screwing things up?
Lem0nHead
Mon Jun 08 2009, 04:15AM
Lem0nHead Registered Member #2096 Joined: Mon Apr 27 2009, 03:08AM
I didn't get much luck with LM311 and left it alone
now I'm trying again
I got the idea of using a DIAC to trigger the SCR
since DIACs usually triggers at 28V, and my capacitors charges up to 160V, maybe using a low current voltage divider is a good idea?
I was thinking about something like 10k/2,2k divisor
Lem0nHead
Mon Jun 08 2009, 07:32AM
well
I just did this simulation on Link2 (File -> Import)
I used a 130V zener instead of a DIAC as I said before... but I guess that will work the same way
the problem here is that the simulator SCR triggers with min 1V and min 10mA... but mine (S6055R) triggers with MAX 1.5V and 5mA
so the current is ok, but how will I send just 1.5V? another divider after the zener?!
$ 1 5.0E-6 51.8012824668342 50 5.0 50
v 128 336 128 96 0 0 40.0 160.0 0.0 0.0 0.5
w 128 96 144 96 0
s 144 96 224 96 0 0 false
w 240 96 224 96 0
w 128 336 240 336 0
r 240 96 240 176 0 270.0
177 336 176 448 192 0 21.865274225784407 0.7833789018714512
w 448 336 336 336 0
w 240 176 336 176 0
w 240 336 336 336 0
w 240 256 240 176 0
r 336 176 336 256 0 600.0
r 336 256 336 336 0 6000.0
z 416 208 416 256 1 0.805904783 130.0
w 448 176 480 176 0
w 448 336 480 336 0
r 480 176 480 256 0 60.0
l 480 256 480 336 0 0.88 0.42163790647825933
c 240 256 240 336 0 0.0013599999999999999 47.09253565640956
w 336 256 416 256 0
o 18 64 0 35 160.0 0.4 0 -1
Lem0nHead
Tue Jun 09 2009, 12:02AM
here I'm trying with 2 zeners
must say it's not being easy
Lem0nHead
Tue Jun 09 2009, 12:49AM
another try... this one seems more promissing
what do you think?
