  • Guests: 48
buxtronix (50)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
variac
audio:deviant
Sun Apr 26 2009, 08:09PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all,
im looking at getting a variac for the ol DRSSTC but i dont really know much about em. how many amps would i need, what would be the minimum. can it be 1 phase? i didnt think they would be so expensive..
Sun Apr 26 2009, 08:43PM
Dalus goes looking for a crystal ball that might tell what you need. We can't give you any information without you first giving us a more detailed discription of the situation.
Your variac should be rated for a larger current then your DRSSTC requires simple.
audio:deviant
Sun Apr 26 2009, 08:46PM
um right, well im building the DRSSTC II from the eastern voltage research book. im on uk mains as well. what other information do you need?
Sun Apr 26 2009, 08:54PM
Well if your sure you want to build this DRSSTC II then you should know what to buy. I'm not going to help you since I suspect that your not capable of building this coil and might even hurt yourself whilst trying.
Come back when you've done some more research and understand what you want and why you want it.
It's also common practice to make a post as complete as possible and check your spelling. Your not putting any effort in this and expect an complete answer from us.
audio:deviant
Mon Apr 27 2009, 10:05AM
um, okay.. im only asking cos in the book it says its 110v 10A so wanted to know if 240 needs the same amps and if anyone had something better i could use. ive pretty much finished building it just need to get this variac and a couple other bits
Mon Apr 27 2009, 11:22AM
Well I can't look in you book since I don't have it myself. But guesstimating if it's build for 110Vac it runs a doubler to give the bridge a higher voltage. If you want to run it on 240Vac you'll need to remove this doubler.
You know the new voltage so do the math. Though going overkill on your variac is a good thing you'll always want more power untill something blows up wink
Coronafix
Mon Apr 27 2009, 10:02PM
Seeing as the EV DRSSTCII runs on 110V, you'll probably find that some of the components will need to be changed for 240V. I think it's safe to say that you'll need at least a 5A rating on the variable transformer.
audio:deviant
Tue Apr 28 2009, 12:15AM
yeah thats what i was thinking. the 5A seem to be a fairly reasonable price which is quite nice.
Tribologist
Wed Apr 29 2009, 03:08PM
Tribologist Registered Member #1879 Joined: Mon Dec 22 2008, 04:11AM
Best place to find good priced variacs are at ham fests. There were a bunch up at MIT's hamfest last weekend. $1 to 5$/Amp is a good estimate on a good day.
You can find hamfests by going to Link2
Ulf
