  • Guests: 40
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Right ZVS Materials?
1 2 3 4
Omicron
Fri Apr 07 2006, 01:12AM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
Hears what I am getting
1N4007 Rectifier Diode
IRFP350 400V 16Amp Mosfet
120 ohm 3 Watt Power Resistor
Will these work for powering Flybacks? AC and DC?
I have got the Coil.
Thanks for all the help
This is all I got, is it all I need?
Desmogod
Fri Apr 07 2006, 01:51AM
Nope, you need an inductor too, roughly 100uH, one out of an old computer PSU should do the trick.
Those 1n4007's are going to get pretty warm, and I'm unsure if they are fast enough, you will kill them. I used MUR840's on mine, which are probably overkill?
You also need some Zeners to clamp the gates. 15Volt jobbies.
EDY19
Fri Apr 07 2006, 01:55AM
I think a lot of people use the UF4007 or something like that- its the same ratings as the 1N4007 but it is a lot faster and shouldn't get as warm or fry as easily.
Omicron
Fri Apr 07 2006, 02:25AM
Where do I get this stuff? I can’t find it on the electronics goldmine.
cjk2
Fri Apr 07 2006, 02:36AM
If you need alot of one part you should try Ebay. Digikey.com and newark.com are also very good, but a bit expensive. In my ZVS i use these.
Michael W.
Fri Apr 07 2006, 02:43AM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
alliedelec.com?
Omicron
Fri Apr 07 2006, 09:36PM
Okay my list is:
1. UF4007 Rectifier; 1.7V; 1A; 1000V; 700Voltage, RMS (40)
2. 1N5352B Diode, Zener; 15V; 5 W @ 75C (Ambient); DO-201AE; 2.5 Ohms @ 75 mA; 1; +175 (40)
3. Flyback Transformer ETF-30L316AYT (10)
4. 120 ohm 2 Watt Power Resistor (Pkg of 200) (1)
5. 120 ohm 3 Watt Power Resistor (Pkg of 50) (2)
6. IRFP350 400V 16Amp Mosfet (10)
7. 2uF 400VDC Film Capacitor (6)
I have the inductor and the coil, so will all this work?
Fri Apr 07 2006, 09:58PM
http://forum.4hv.org/attachments/Flyback_driver.png
Look yourself what you need more...and give it a try.
Omicron
Fri Apr 07 2006, 10:04PM
This is what I am useing Link2
Fri Apr 07 2006, 10:09PM
Registered Member #256 Joined:
looks like ur link didnt work out too well , oh well, its the same one anyways right? could zvs be used for sstc? i hear this zvs is one of the best for driving flybacks, why the need for 10+ amps? good luck with ur driver omicron
