  • Guests: 45
SSTC feedback antenna clamping diodes
iRET
Mon Apr 20 2009, 02:23AM Print
iRET Registered Member #258 Joined: Sun Feb 26 2006, 03:58PM
Planning to built this SSTC,
but having some doubt on exact components usage. Diodes D1 and D2 are Germanium glass diodes 1N60, can these be replaced with silicon based diodes like 1N4148 ?
teslacoolguy
Mon Apr 20 2009, 02:31AM
1n4148 diodes will work just fine.
iRET
Mon Apr 20 2009, 02:44AM
Thanks Teslacoolguy, btw nice website !
MRacerxdl
Mon Apr 20 2009, 04:03AM
The diodes needs only to be fast enough to clamp the voltage at input... The Germanium Diodes have less voltage drop. So is more safe using then... And usually have higher frequency rate than normal sillicon ones. But I never have used Germanium diodes in my entire life =P
lhl_henrylui
Mon Apr 20 2009, 04:55AM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
Can I use a 1n4148 to be the demodulator of a crystal radio?
The circuits on the internet usually tell me to use 2AP9,OA70,etc.But I can't find them.
iRET
Mon Apr 20 2009, 05:11AM
Same boat over here. Anyway, will try to locate some cheapo 1N60 to try out. I wonder whether the same antenna feedback circuit topology would work on flyback transformer or ignition coil... any ideas ?
Myke
Mon Apr 20 2009, 01:28PM
lhl_henrylui wrote ...
I don't think that the 1N4148 is good for demodulating crystal radios. The 1N4148 is not a germanium diode and has a higher voltage drop (and I think reverse recovery time). Germanium diodes like the 1N34A are more expensive than the diodes like the 1N4148.
Mon Apr 20 2009, 04:46PM
I have always used 1n4148's, but i wonder if clamping would be better with the germanium diodes? LEss voltage drop is definitely good. Also, low leakage current is nice, unless both diodes have the exact same leakage current, which no two do.
I shouldn't be expressing my opinions, but this Link2 sstc might be better. The only real difference is it uses and interrupter, a class E shunt capacitor, and a voltage doubler. You could use the TC4420 instead of the UCC, i think. Just a thought.
Mon Apr 20 2009, 05:05PM
6.5 dollar for 50x 1N60 (shipping included) : Link2
Mike
Mon Apr 20 2009, 07:47PM
Arcstarter wrote ...
Class E sstc's are not something for a beginner to making considering the amount of tuning and adjustments that have to be made to actually have it run in Class E operation. If the poster isn't a beginner though disregard this I guess.
