  • Guests: 63
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
CNC Pcb etcher -NOW MOVING
Tue May 05 2009, 08:10PM
I did experiment with spin coating other surfaces with photoresist using a spare PSU fan motor.. worked fairly well.
Main issue is that the focus adjustment is incredibly finicky even with a good module. I along with the combined intellects of #hvcomm came up with a fix involving rotating or otherwise moving a suitably shaped large lens so that the laser beam intersects different areas to "fine tune" focus as required.
inspired by the mini lens/motor unit in the PS3 modules.
Also it is interesting to note that in theory you can use a motor with preset "beam plate" stencil rotating to one of n preset locations, reducing the time required to "scan" the board by generating existing common pin layouts, then completing the process by "linking point to point".
I stumbled across this method by shining UV LED light through a sheet of Veroboard, and the resulting PCB development had nice sharp edges.
This might also allow a UV LED array to be used instead of the expensive laser.
-A
twist2b
Tue May 05 2009, 10:32PM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
That is very cool!!!!
I love CNC machines myself. After college I plan to get one for any projects... Can you take picks of your CNC machine that has a Zeta plane?
I don't think I would want to build one though :P
It looks costly :o and mistakes = costlier.
Dr. H.
Fri May 08 2009, 07:20AM
Good day guys
some progress on the cnc. I've made all boards and put them in the box... weeeel you know how at one point the box just gets a bit to smaaaalll wink WELCOME TO THE JUNGLE hee hee. Connected everything and started testing. Some problems poped but will remove them and hopefully - first movement tomorrow or even tonight.
twist2b wrote ...
Hi there - I've posted few pics up the thread. If you are interested in something more specificaly -please write.
Here is the jungle:
1241767252 931 FT67809 Pic 6409
1241767252 931 FT67809 Pic 6418
Linas
Fri May 08 2009, 04:18PM
nicely done smile
when you are going finish this CNC ? ( i mean completely)
Dr. H.
Fri May 08 2009, 04:44PM
Good day guys
no idea about finishing it, because I have exams soon and not much time. But every spare time goes to it. I've finaly got it moving. Here is a video Link2 - I am driving it trough the keyboard. Still alot of tuning to be done and test a G-code on it. Also here is a pic how it all looks.
Cheers :)
1241801039 931 FT67809 Pic 6422
1241801039 931 FT67809 Pic 6419
Chris Cristini
Fri May 08 2009, 05:00PM
Chris Cristini Registered Member #1749 Joined: Fri Oct 10 2008, 02:04AM
Yes good job.!!! cheesey
Sat May 09 2009, 05:12PM
Also if you haven't already, add a safety interlock to prevent laser running when the cover is open (or limit its power to safe levels). Its also possible to increase resolution by adding the zone plate from a PS3 module, and adding a second "prefocus" lens behind the main one.
Just a thought but my version is using the SLA7062M microstepping IC (fairly cheap, and the pcb is simple) ever heard of this IC?
-A
