  • Guests: 42
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
drsstc II boards
audio:deviant
Wed Apr 15 2009, 03:39PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all, im trying to build a drsstc (easternvoltageresearch) for the first time and have no idea where i can either buy some boards or get the artwork to make them. can someone give me some advice?
cheers.
Wed Apr 15 2009, 04:23PM
You might want to use google as a search function instead of just asking and let us do the searching. My advice is to look up and find this thread Link2
audio:deviant
Wed Apr 15 2009, 04:33PM
im not trying to build the mini brute thats the issue. i was after some specific boards for the bigger drsstc II thats in the book itself. but havent had much luck in finding them. unless im searching for the wrong thing.
Wed Apr 15 2009, 06:23PM
the bigger DRSSTC II uses the same circuitry as the minibrute. The dimensions of the tesla coil (primary / secondary) are just larger.
Use the minibrute boards for that design.
audio:deviant
Wed Apr 15 2009, 07:11PM
okay cool, is it just the resonant driver, half-bridge, rectifier. that i can use cos the main capacitor assembly is massively bigger?
thanks for the fast reply by the way. most appreciated.
MRacerxdl
Wed Apr 15 2009, 08:48PM
Usually the driver is the same for all DRSSTC's, from little ones to bigger ones, the difference goes what current you want put at the primary coil... That changes the igbts that you use, and primary wire diameter (or copper tubing)
audio:deviant
Wed Apr 15 2009, 11:05PM
the mini brute is a half bridge system and the other is full dont really under stand this if im honest... i presume its just a few different components then. oh speaking of tesla coils got some serious lightning going on at the moment!
Thu Apr 16 2009, 04:54AM
If you don't really know much about teslacoils I would stay away from DRSSTC's especially large ones they are quite troublesome to get working properly.
Thu Apr 16 2009, 03:06PM
I recommend half-bridges as opposed to full-bridges for higher reliability and simplicity. The miniBrute design, which uses a half-bridge, can be scaled up for use with larger coils.
And as Mestre stated, the drive circuits are basically all the same from mini to giant sized DRSSTCs. Its just the power section (bridge) that varies, and usually its just the components in those bridges that vary (i.e. 40N60 IGBTs vs. larger CM600's, etc...)
audio:deviant
Fri Apr 17 2009, 03:04PM
i've got the boards now, (minibrute) just on the parts ordering now.. going by the building the modern day Tesla coil book as this is my first coil. any advice going slightly off topic.
