  • Guests: 29
Electric vehicle?
Chris Cristini
Mon Apr 13 2009, 06:04PM Print
I was thinking if I had the money to waist I would buy all these things to make a electric tricycle with these items. the motor Link2 the controller Link2 the batteries Link2 *6 the tricycle Link2
maybe replace the basket with the batteries and the controller and replace the thin wheels with motorcycle wheels. And I was thinking it would be cool to make a differential for the PMG 132 or the PMG 080 here Link2 It would be crazy to be able to do some thing like this what do you think?
1239645858 1749 FT0 Electric Tricycle Rear End
Chris Cristini
Tue Apr 14 2009, 12:51AM
I am sorry for double posting I can't seem to find out how to add pictures when editing.
1239670278 1749 FT67587 Controller Dia
Download
Tue Apr 14 2009, 03:03AM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
Chris Cramer wrote ...
use [img] tags
Mike
Tue Apr 14 2009, 04:10AM
maybe its just me but that seems like a ridiculous amount of power for a device that is normally meant to go top speeds of 15mph.
Chris Cristini
Tue Apr 14 2009, 09:01AM
I was planing on making something like it but with bigger tires and disk brakes thicker frame I should have been a little more specific. I apologize.
Chris Cristini
Fri Apr 17 2009, 03:57PM
What about this one it is an all wheel drive gocart Link2
Bjørn
Fri Apr 17 2009, 04:16PM
Instead of all those gears, why not add one motor for each wheel, it is probably going to be simpler, it will also give better traction.
Have a look at cheap and powerful brushless motors. The tiny ones can deliver several kW. Something like this but with one smaller motor on each wheel. Link2
Chris Cristini
Sat Apr 18 2009, 04:57AM
Haha I never would have expected something like that do you know why they used a clutch an electric motor is better for low end torque right. But look at these I think this bike has the PMG 132 with a neet little heat sink wrapped around it. Link2
And this has the PMG 132 at 48V it said 63MPH but I am not looking for speed I just want something that will climb a mountain I think it would be fun. Link2 It just so cool that these motors are so small for there output.
Oh here is an other one. Link2 And another. Link2
Bjørn
Sat Apr 18 2009, 05:17AM
You are right that an electric motor has much higher torque at low rpm. I can guess that the motor controllers were not designed for very low rpm and possibly extreme currents so a clutch is a simple way to protect them.
Remember that even if it is electric it is not a toy, A 15 kW motor can kill you in just a couple of seconds and if you short the batteries with yourself or something else you might end up just as dead.
Chris Cristini
Sat Apr 18 2009, 05:26PM
Oh yea I know the dangers but honestly everything we do can be deadly from high voltage output of a VTTC driving a car every day or just walking down the road just keep in mind that there is a point to the danger of what you are doing if you show respect and care for what you are doing you will be fine don't let the previous thread about high voltage mistakes fool you I show a lot of care when it comes to certan death and if I do ever build something with this power it is not going to be 72V right off just got to start off slow and work out the kinks and most important the safety of me and the $1000 motor. cheesey Honestly is it any different than four wheelers and dirt bikes or even motor cycles there is a lot of power and speed people die every year on them they are considered to be fun when I get into thinking about safety it alway gets to you can never be safe even in the comfort of your own home.
