  • Guests: 62
Unknown flyback transformer
lhl_henrylui
Sat Apr 11 2009, 01:33PM Print
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
I've got this FBT recently but I wanna know the pin configuration of it. Can anyone give me the data sheet of it?I'm sorry that the labels on it are not clear enough but I'll upload more image of ti later.
Another qeustion: What's the use of the two wires above the pins and that of the two buttons on the FBT?
1239456831 1498 FT0 Img 0067
1239456831 1498 FT0 Img 0066
Sat Apr 11 2009, 01:39PM
The two wires are focus and screen.
You can find the HV return pin by connecting the negative of your >20V supply to the HV output and the positive to one lead of a voltmeter, while probing the pins on the base with your other probe. The one which gives highest voltage reading is the HV return.
You don't need to know the other pins as you'll wind your primary on the exposed core anyway.
BTW this transformer has a built-in HV capacitor so it is not suitable for drawing arcs.
lhl_henrylui
Sat Apr 11 2009, 01:49PM
What's the use of the two wires above the pins?
1239457876 1498 FT67393 Img 0068
Dr. Kilovolt wrote ...
What's the meaning of "BTW"?And why it's not suitable for drawing arc?
edited by Noelle to combine triple posts
Sat Apr 11 2009, 02:02PM
lhl_henrylui wrote ...
They provide focus and screen voltages to the CRT tube.
Edit: BTW means "by the way". When there is a capacitor on the output of the transformer, you won't get hot arcs but just loud individual sparks which can't be drawn.
Killa-X
Sat Apr 11 2009, 06:21PM
How high do you think the HV capacitor is Dr. Kilovolt? Most likely too slow to be part of a teslacoil capacitor id guess (if you wanted to bother with boiling the core and removing it all...That's too bad that he ended up finding one that has a built-in capacitor to kill all the fun of arcing :(
Sat Apr 11 2009, 06:53PM
Well, sometimes the cap has a separate ground connection in which case it can be left floating, but as you start outputting a few tens of kV it will most likely spark over.
You can still use it for Tesla coil if you put a high voltage resistor in series with the output which limits the discharge current to a few Amps.
There is also a possibility to draw arcs from it if you put a suitable high voltage inductor in series with the output (this can be a flyback-secondary-like coil on a ferrite core, maybe even a ferrite rod is enough).
Don
Sat Apr 11 2009, 10:40PM
Don Registered Member #2075 Joined: Sat Apr 11 2009, 10:38PM
How can you tell if the FBT has a built in HV capacitor?
Sat Apr 11 2009, 10:58PM
Don wrote ...
You power it up and if it is a loud white spark it is a capacitor XD.
If the flyback looks like it has a kind of square or rectangle place on it, that is likely the HV capacitor. I have taken a sledge hammer to a dead flyback which had a capacitor, and it was indeed just a type of film. It was pretty large, actually. About half as big as the whole flyback. Considering the capacitor had to be made to withstand a constant 25-30kv, i would have to say it was a few nf, like 1-5 or so.
Just a guess, that was only judging by the physical dimensions.
lhl_henrylui
Mon Apr 13 2009, 05:39AM
I also have a smaller FBT.Can I combine them together?A twin system?
Backyard Skunkworks
Mon Apr 13 2009, 05:56PM
Yes
