  • Guests: 38
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
DRSSTC Request for info/advice
Angstrom
Thu Apr 09 2009, 08:26PM Print
Angstrom Registered Member #1900 Joined: Fri Jan 02 2009, 06:44PM
Hi all,
I posted a while ago about an SGTC project but since then i've moved on to solid state - it looks far more fun. I plan for it to be a 2 foot secondary (30AWG) with a 25" toroid (rigid aluminium ducting) for a low fres (75kHz), and a helical primary with 0.3uF MMC - the price of the Cornell caps on digikey isn't bad! Also, I came across quite a few Powerex CM50 IGBTs that I plan to use at first since I anticipate burning several of them out. I have been told that they could still be quite effective and achieve high peak currents despite the low RMS current rating - what can I really expect here?
Anyway my questions:
1. How are people making the bridge? An obvious solution is just another PCB that is mostly copper - but I figure there's easier ways. Suggestions?
2. My primary goal is audio modulation which I know requires programming a microcontroller. I am an engineering student so I am somewhat prepared for this although my current knowledge is limited (I have only used a PIC18). I know most people keep pretty quiet about their audio mod systems, but I am looking for some push in the right direction - such as resources on signal conversion (esp. MIDI) and just what formats people have used (e.g. what microcontrollers/language?)
Thanks
Corey
Thu Apr 09 2009, 11:56PM
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
i have not yet built any solid state Tesla coil, but as for understanding operation and such i found Steve Ward's site to be quite inebriating. Good Luck!!! link---> http://stevehv.4hv.org/SSTCindex.htm
Angstrom
Fri Apr 10 2009, 12:14PM
Believe me i've already scoured his website :)
Renesis
Fri Apr 10 2009, 12:52PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
I am currently waiting for a book i've ordered, i believe that book would answer your questions too.
Zappy
Fri Apr 10 2009, 05:01PM
Zappy Registered Member #2054 Joined: Tue Mar 31 2009, 05:24PM
Projects like these I usually build with experimenter's board, you know, the 100x160mm cards with all the 0.1" spaced holes in them with copper islands. I never etch PCBs unless there is more than one board to be built. Large power devices are mounted onto heatsinks and then wired to their associated components mounted on the board. Or just use a plain piece of copper clad board (the "haywire" technique). Or don't use any board at all, just have everything floating with some blobs of glue to the heatsink (not hot-melt!!!) if needed. And of course use nice thick wiring for your power semiconductors.
