  • Guests: 57
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Matchbox size welding inverter
Thu Apr 09 2009, 07:00PM Print
Link2 The english description is at the end of the page.
GeordieBoy
Thu Apr 09 2009, 07:38PM
That is certainly quite compact power electronics!
On a practical note, whilst it is clearly functional, I doubt it complies with US or European safety or EMI standards. Often it is not getting high power density that is the problem in power electronics, but finding space for input and output filtering components to meet approvals standards! These tend to form a significant volume and weight of products designed for EU markets.
From a safety point of view, exposed transistor leads carrying 100 Amps, no mains switch/circuit breaker and a plastic enclosure close to the welding head don't look good!
-Richie,
EEYORE
Thu Apr 09 2009, 07:53PM
Looks to be right up our ally here at 4hv! Haha! I like the exposed transistor leads as well! So what if some of the sparking metal gets inbetween the transistor leads? BOOM makes for a good story! EMI? Oh well! Deny everything if something nasty gets back into the mains from that inverter!
Man thats compact though!
Matt
Renesis
Thu Apr 09 2009, 07:57PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Yeah... right...
A duty factor of 25% at 100A is just sad, but yet i think it sounds too inbelievable. Look at that tiny heatsink? The welder obviously works, i doubt the images are fake, but a welder also need some arc stability. Small/cheap welders are generally difficult to use.
And i bet that digital display will be unreadable after some showers of weld splatter tongue
But then again, that is amazingly compact electronics.
Thu Apr 09 2009, 08:12PM
What's that smell? BS probably!
I'd guess that the "ground clip" wire just goes straight through the plastic box to the electrode, and it clips onto the output of a real arc welder under the table for demo purposes. The mains power cord probably just runs the display.
Why do I think this smells of BS? Well, if you were designing the world's smallest inverter, would you start by wasting 30% of the internal volume on a big chunky set of 7-segment LED displays, when you can now buy wafer-thin LCDs and OLEDs even in hobby stores?
I would also expect to see a stack of aluminium core PCBs with force cooling by a fan, not a Radio Shack plastic box and heatsink.
Hon1nbo
Thu Apr 09 2009, 08:31PM
Steve McConner wrote ...
I have to agree... and that would explain so much "secrecy" listed in the details (I used Google to translate) - and Steve makes a very good point regarding the use of the LED type display, which makes no sense whatsoever... also, even at a 25% duty cycle that transistor would need some serious cooling, and having a passive heat sink attached to a plastic box would produce some serious hazards to the casing, and components inside
so I have to call BS on this as well... while I would be happy for such a thing, I need to see some harder evidence then this.
Thu Apr 09 2009, 08:41PM
Look at the publish date cheesey
Thu Apr 09 2009, 09:29PM
Thats crazy! The exposed leads are awesome!
Here is the translated version: Link2
Renesis
Thu Apr 09 2009, 09:33PM
ahh
EEYORE
Thu Apr 09 2009, 11:36PM
Thats alot of work for an April fools day joke. tongue
Matt
