  • Guests: 79
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Toroid or not Toroid?
Zappy
Thu Apr 09 2009, 04:52PM Print
Zappy Registered Member #2054 Joined: Tue Mar 31 2009, 05:24PM
My current Tesla project uses a aluminum foil clad polystyrene sphere as topload:
Vttc2 First Streamer
Everywhere else toroids are used. I can't find a comparison between a sperical and toroidal topload. Why is this? Why should I build a toroid?
Herr Zapp
Thu Apr 09 2009, 05:07PM
Regenpak -
For use as a topload on a Tesla coil, a properly-sized toroid has several advantages over a sphere, primarily due to better "shaping" of the electrostatic field around the topload:
1. A toroid provides better "shielding" of the top turns of the secondary. As you crank up the output of a TC with a spherical topload, you will get lots of corona (and eventually arcing) from the top secondary turns.
2. A toroid will generally tend to direct streamers away from the secondary, reducing the potential for "self-strikes" that can damage or destroy the secondary.
Regards,
Herr Zapp
Zappy
Thu Apr 09 2009, 07:25PM
Herr Zapp:
This makes a lot of sense, and is very helpful. When I've figured out the primary of my project above I no doubt will run into exactly the problems you describe.
Many thanx!
Fri Apr 10 2009, 08:57AM
Sorry for OT but I found that "ZAPPY TV" sticker on one of the meters amusing cheesey cheesey
A TV is indeed zappy, especially if you attemt to clean it with a wet towel, I have learnt the hard way...
Zappy
Fri Apr 10 2009, 04:50PM
Actually, ZAPPY is an old nick from me, from like the early 80's. Then it got abused as logins all over the place. Should have used it here as well... tongue
Plasma Lover
Fri Apr 10 2009, 06:33PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Regenpak wrote ...
Wow, we're getting really OT..... anyways, if you like, you can change your username in the login settings. They're on the left side of the screen above your message inbox.
Sat Apr 11 2009, 06:28AM
With a toroid you will also have a larger surface, so you would need a large sphere to bring down resonance to the same frequency as you would only need a rather small toroid to do so.
Zappy
Sat Apr 11 2009, 07:08AM
I'll patronize my local hardware store and see if they can accommodate me...
-Zappy
RogerInOhio
Sat Apr 11 2009, 09:39AM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
For a VTTC or a solid state Tesla coil I don't think it matters as much whether you use a sphere of a toroid. The toroid might be a little better but they are harder to make.
1239442616 1034 FT67281 Aprtube1
Zappy
Sat Apr 11 2009, 08:04PM
RogerInOhio wrote ...
That I already found out...
-Zappy
