  • Guests: 38
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
GMI-90 Project ideas
Dr. H.
Sat Apr 04 2009, 08:17PM Print
Good day guys
I've got one of those tubes (GMI-90) and I was wondering what project to do with it.
It is a tetrode with some interesting specs shades
33kV (yes 33kV) anode voltage suprised
anode current - pulsed - 40Amps (3uS duratation)
Power on the plate - 140W (yes a little low)
Here some info on the tube Link2
And some pics afcourse smile
(it is the one on the left - the others are for reference)
All ideas are welcome :)
Cheers
1238876151 931 FT0 Pic 6288
1238876151 931 FT0 Pic 6291
1238876151 931 FT0 Pic 6294
Sat Apr 04 2009, 09:43PM
There is always the regular vttc, but you could perhaps put a small twist on it. Vacuum tube disruptive coil XD. 40 amps is really low for this though, soooo...
You could make a hf vttc, since it is a tetrode. You know, the 'plasma tweeter' circuit, secondary base fed and no primary.
A very ridiculous audio amp (yes this is a joke, unless you wanna be a bit different XD)
A low power induction heater.
A hf oscillator for assorted thing.
What would you use for power? A flyback is what i would use shades . Have fun, good luck!
Dr. Drone
Sun Apr 05 2009, 08:19AM
shades
Littlew
Sun Apr 05 2009, 06:39PM
Littlew Registered Member #1448 Joined: Sat Apr 19 2008, 01:16PM
You can make pulsed vttc or earn some money(gmi-90 had 0.7g of gold and gmi-7 had 2g of gold and 0.1g of silver)
Dr. H.
Sun Apr 05 2009, 07:05PM
Good day guys
I will most likely go with the Bipolar VTTC but will be open for ideas because it won't be soon when I will start that project.
Hmm break the tube and get the gold to sell it ?!? - I can make much more by selling the whole tube. And how can you break such a beauty ?!? This thing is staying with me, if not used - will go to a good friend of mine smile
Cheers
Sun Apr 05 2009, 08:51PM
I'd go for a disruptive DRVTTC for sure. 30 amps might not seem like much, but remember it's 30 amps at 33kV: 1 megawatt of pulse power.
Even allowing for some derating, as a disruptive coil burst is typically 150us, not 3, I'd still expect sparks over 3ft from it. Maybe only 1 or 2 per second on account of the 140W continuous plate rating.
Sun Apr 05 2009, 09:10PM
See Mr. Conner has the right idea XD. Just use low tank capacitance. You could make a normal Dc resonant charging power supply, and use the tube as if it where a spark gap. I tend to think that might be easier on the tube, as it does not have to oscillate at such high freq, and you would use an anti-parallel diode to carry the oscillations on so that would only be half of the oscillations the tube has to conduct for. Then you can use a higher breakrate and stuff. It could use sidacs to trigger the tube at the right voltage. I was thinking something like the sidac's in series, when they break down they charge a small capacitor up, then some TVS's could let the cap only charge high enough. On the sidacs you would of course have a power resistor to keep tank cap from discharging through the sidacs. The capacitor could be adjusted to set on time, and it would have a bleeder across it.
You could also use a low freq oscillator and a half or full bridge, running a steup/isolation transformer tied to the grid. (gdt now equals GRID drive transformer :P)
Just ideas that for some reason i thought i should write down...
Dr. H.
Mon Apr 06 2009, 05:56AM
Good day guys
BIG thanks on the repplys smile
Now for the disruptive DRVTTC - I've been thinking on that for a long time and for it I have a much "better" tube than this one.
A russian triode at 10kV plate, 1A continuous (130A pulse) and 4kW dissipation power on the plate.
Hmm 2-3 burst in a secound sounds a "little too little". Any suggestions welcome smile
Cheers !
Mon Apr 06 2009, 03:38PM
Nice looking tube. I have one also in my collection for a future project:
Th
...but this will be only after I would finish the GU5B project. Unfortunately, I had not enough time lately. I just managed to build the primary cap and the cooling pipe (for GU5B) only:
Th
Th
I still dont know how to put the tube (GU5B): anode up or down. The device is made for the tube with the fillament connections up..
I thought to a bipolar VTTC too for the gmi90, center grounded, g2 modulated (as a drsstc). When the project will be started I dont know....
Mon Apr 06 2009, 10:21PM
Given the voltage, maybe Audio Amp for electrostatic speakers?
I know they use a rather high voltage, maybe 30 KV would do?
(I don't except it to be used for that, anyway... but just an idea)
