  • Guests: 67
My first DRSSTC
wicked alex
Sat Apr 04 2009, 01:38PM Print
wicked alex Registered Member #1786 Joined: Tue Oct 28 2008, 03:23PM
Hi, here is my first drsstc its is the same as the drsstc 5 from CTC labs. Link2
Link2 easy tuned
Link2 untuned
And the secondary is so smal becose i yoused one of my sstc (i will make a bigger one)
And at full batteris i get up to 5cm sparks at 36v.
But i have one problem my gdt driver IC's ar getting very hot after 30sec.
sorry for my bad english
teslacoolguy
Sat Apr 04 2009, 02:21PM
hmm, it looks like you are running at a very high "ON time" based on the look of the spark. You many want to decrease that because it will keep your igbt's and primary cap happier. It could also be the reason your GDT driver ic's are heating.
wicked alex
Thu Apr 16 2009, 04:16PM
Link2 It works!
Secondary: 7.5cm in diameter, 16cm high wound with 0.15mm.
Resonanc. : 210khz
gangster
Thu Apr 16 2009, 08:46PM
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
very nice results alex smile . what type of driver do you use? feedback with CT ?
sorry for my bad english :)
Myke
Fri Apr 17 2009, 01:27AM
Wow. It looks really nice. What's the approximate ratio of spark length to height in that video? Could we see pics of the final setup once you change the secondary?
BSVi
Fri Apr 17 2009, 06:43AM
BSVi Registered Member #1637 Joined: Sat Aug 16 2008, 04:47AM
This coil is realy cool! The only bad thing about it is that interruptor input of driver doesnt have zero cross synchronization.
wicked alex
Fri Apr 17 2009, 12:13PM
Myke wrote ...
It is 4.25X (max. sparklegth is 68cm)
wicked alex
Fri Apr 17 2009, 07:08PM
PIC's!
