  • Guests: 48
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
longitudinal excitation nitrogen laser
radhoo
Wed Nov 09 2011, 08:25AM
I got my fridge pump, so I'll be trying this myself soon.
cedric
Fri Nov 11 2011, 11:37AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
I get my new laser to work, using the fridge pump , for this I vaccum a wine bottle, I vaccum the laser cavity ,and while the pump is still runing I fix the wine bottle (not half full of amptyness) to the output of the pump, effectively making a double stage pump...
hboy007
Fri Nov 11 2011, 12:17PM
cedric wrote ...
That's a pretty neat trick. Have you tried using a larger gas cylinder? Apart from the larger volume, they don't have the habit of shattering while you're (not) looking.
cedric
Mon Nov 14 2011, 08:51PM
hboy007 wrote ...
cedric wrote ...
I didn't have any thing like that around , but I put a piece of fabric around the bottle...
radhoo
Wed Dec 21 2011, 04:48PM
My first tests of the build itself. No resonant circuit yet, just the tube, endings, HV supply (50KV) and a fridge pump for vacuum:
47
11
cedric
Fri Dec 23 2011, 03:19AM
doesn't look to bad , what is the size of the tube?and how are you planing to align the optics?
ahahn
Fri Nov 23 2012, 09:37AM
ahahn Registered Member #6075 Joined: Wed Aug 08 2012, 11:48PM
hboy007 wrote ...
radhoo wrote ...
So you're saying I can simply use one of these: Link2 and forget about the vacuum pump at all?
Well, see for yourself: Link2 Link2
The higher the pressure, the narrower the pumping window, we're talking about ~1ns for nitrogen at atmospheric pressure.
There exists a relation for the lifetime of the excited level as a function of the operating pressure: 746ad03ee9ff7b4ae3dbf7c17d218740
A peaking capacitor is introduced to compensate for the "slow" marx bank.
I'm trying to do this, unfortunately it's not at all clear how to calculate the value of the peaking capacitor. Some sources suggest it's a function of the Marx bank's inductance, but some of the LE Marx-powered nitrogen lasers use quite large peaking capacitors despite Marxes of fairly non-inductive appearance... and a bit of further research suggests getting the value of the peaking cap right is critical to minimizing risetime.
Any ideas?
