  • Guests: 44
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Element Collection
Electrikid221MnM
Sun Nov 18 2012, 01:51PM Print
Electrikid221MnM Registered Member #4172 Joined: Sat Oct 29 2011, 05:57PM
I bought a book recently, "The Elements" by Theodore Gray (or Grey) which inspired me to start collecting samples of the elements up to 95, and even some elements up to 86 can be pretty nasty if not stored correctly, so certain elements I will probably just have items related to them. I've already obtained Aluminum, Silicon, Phosphorous, Calcium, Iron, Copper, Germanium, Krypton, Cerium, Neodymium, Europium (CFL's), Tungsten, Gold, Lead, and .9 microcuries of Americium (Ionization Smoke Detector) sealed into a case with gold film. I did not remove it from the casing, because then I would be exposed to radioactivity. Element collecting is a very fun thing to do mainly because you know you have one of the materials that are the bricks and cement of the universe.
1353246664 4172 FT0 Image
Hazmatt_(The Underdog)
Sun Nov 18 2012, 04:45PM
How about some old thermostats?
HEHEH. YAY Mercury!
023f
Sun Nov 18 2012, 05:45PM
i need several pounds of plutonium... without a whole lot of questions from the CIA/FSB/NKVD and what not.
Electrikid221MnM
Sun Nov 18 2012, 06:56PM
Haha, no plutonium here
Sun Nov 18 2012, 08:51PM
Electrikid221MnM wrote ...
..... and .9 microcuries of Americium (Ionization Smoke Detector) sealed into a case with gold film. I did not remove it from the casing, because then I would be exposed to radioactivity.....
it looks like you may have disasembled enough already, to expose the americium. did you remove the metal cover with the louvers on it?
Electrikid221MnM
Sun Nov 18 2012, 08:57PM
No, just pulled the unit off the board since it wasn't soldered.
Sun Nov 18 2012, 09:24PM
you might want to keep that in a lead foil and ventilated place.
Electrikid221MnM
Sun Nov 18 2012, 11:23PM
ok
zrg
Sun Nov 18 2012, 11:41PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
How about neon and other inert gases in the form of their chemical symbols?
PM me if interested.
1353282086 4762 FT146717 Dsc 5579
1353282086 4762 FT146717 Dsc 5582
Tue Nov 20 2012, 02:37AM
The gas displays would be totally cool!
I got no money though..
