  • Guests: 51
Really good transformer
KLH
Sun Mar 29 2009, 10:59PM Print
Seems like a transformer like this would be very useful in a capacitor charger (connected in reverse). It would also be useful as a generic power supply transformer.
http://www.raftabtronics.com/PRODUCTS/HXMTTransformers/tabid/53/ctl/Detail/mid/365/xmid/1/xmfid/1/Default.aspx
What do you think?
teslacoolguy
Sun Mar 29 2009, 11:34PM
WOW 404 error xD
Nice transformer, may be able to power that directly from a zvs driver because the primary (in our case) is centertapped.
rp181
Mon Mar 30 2009, 01:02AM
404 here too.
I think that would work great, due to its high frequency and small size. Where can you buy them?
Chris Cristini
Mon Mar 30 2009, 01:28AM
404 I need one how do they go for just kidding.
KLH
Mon Mar 30 2009, 05:55PM
Chris Cramer wrote ...
That's what I want to know; too bad you can't get samples or order online.
If the link isn't working you can paste the URL into the address bar. I can't seem to fix the link.
Mon Mar 30 2009, 06:47PM
for the thousandth time, you can either put the link without url tags and (just put the link in the text of your post) and it will turn into a green arrow Link2
or put it in a url tag replacing 'hyperlink url' with your url, and putting text inside the tag omg 400v uuber transfomer click!!!11
(you can click the 'quote' button to see the code used to make this post
In any case, if they will sell you one it seems like a resonably easy way to make a capacitor charger, but you may as well just steel a transformer out of an atx psu, I would expect it to have similar ratings (although you may have to use a fullwave votlage doubler or the likes on the output to get a full 400v out of it)
Zum Beispiel
Mon Mar 30 2009, 09:25PM
You do realize that your link is broken too? cheesey
KLH
Mon Mar 30 2009, 09:27PM
... wrote ...
Whoops, didn't know about that feature. I haven't seen anywhere before how to do this, but I also haven't tried quoting another post.
Anyway, I wanted to point this particular transformer out, because I don't like to salvage parts due to possible variation or unavailability (if the salvaged part is destroyed). If I ever get my hands on one of these transformers and create a capacitor charger, I'll post about it.
The link you placed is broken because of a </br> tag.
LithiumLord
Tue Mar 31 2009, 08:22AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
hmm, I guess the ZVS isn't very usefull here. The resulting frequency will be floating and will cause different resonant effects that may become harmfull. I'd recommand an open-loop push-pull driver running on the recommended 150kHz instead.
Tue Mar 31 2009, 11:13AM
What's wrong with a series light bulb + rectifier/voltage multiplier for charging caps? Easy and relaible.
