  • Guests: 58
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
My first zvs attempt
Zee
Sat Mar 28 2009, 08:20PM Print
Zee Registered Member #877 Joined: Tue Jul 03 2007, 09:15PM
Finally had the parts to put together my first zvs flyback as to join to "the group". :)
Not much but still an advancement from the first 2n3055 flyback. Maybe some of the parts are way overkill. Caps warm up a bit after a while of use but besides that it seems to be running cool.
http://oms.wmhost.com/pics/30kV/zvs_whole.jpg
http://oms.wmhost.com/pics/30kV/zvs_psu.jpg
http://oms.wmhost.com/pics/30kV/zvs_driver.jpg
http://oms.wmhost.com/pics/30kV/zvs_primary.jpg
And then the "live" results:
http://oms.wmhost.com/vids/30kV/zvs.avi
cjk2
Sat Mar 28 2009, 08:50PM
Nicely done.
Pictures should be 400px (or is it 450px?) wide, you will want to resize them or use thumbnails.
Youtube is also nice for hosting videos, I think you will find that fewer people watch your videos when they have to download the AVI rather than simply going to youtube.
What voltage are you running at?
theju
Sat Mar 28 2009, 08:59PM
theju Registered Member #1445 Joined: Tue Apr 15 2008, 01:25PM
nice work, but i would use shorter connections to the flyback transformer
and the capacitor is suboptimal, you should replace it with a mkp10 or fkp type
then it won´t heat up :P
Tonskulus
Sat Mar 28 2009, 09:02PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Haha, i knew you are from Finland. I recognized you out of those components (trafox, muuntosähkö oy transformer).
Anyway, welcome!
Zee
Sat Mar 28 2009, 09:19PM
Changed the images into links... Have to check the youtube option too. I have an account there but never uploaded any vids.
Tonskulus:
Hah, seems the brand is quite familiar. :)
Myke
Sat Mar 28 2009, 11:01PM
Nice work. I like the compactness of the driver. If you add more filter capacitance then you will get rid of the humming when you draw the arc. What are the ratings on your supply?
theju wrote ...
I agree. You should either use more caps and make a small MMC bank or get a better cap that can handle more power so it doesn't heat up at higher powers.
Why should he shorten the connections to the flyback? Stray inductance in series with the flyback's primary doesn't affect the operation of the driver that much. I think that keeping the stry inductance between the caps and the MOSFETs are more important.
3l3ctrici7y
Sat Mar 28 2009, 11:35PM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Youtube sucks, they transcode, and downsample whatever you upload into that crap flv format. Now, more recently, they support mp4, but it is still transcoding what you upload; with the inherent quality reduction... caused by the transcoding. I'll take a file that is the direct output of the thing that took the video in the first place over a mangled yousuck video any day!
theju
Sat Mar 28 2009, 11:42PM
the long connection means more losses cause of higher resistance :P
that the inductiance doesn´t effect is true
Zee
Wed Apr 01 2009, 04:35PM
cjk2 wrote ...
Myke wrote ...
Transformer is 230V 180VA on the primary side, 2x12V on the secondary. Other than that, difficult to say. I propably didn't pay enough attention while in school to understand all the powerfactor stuff.
Measuring from the rectifier section the output is 16VDC when idle and 12.5VDC when drawing arcs.
And replacing the cap would do. Even seems to warm up when sitting idle. But the filtering is ok as is. I like the humming arc. Sounds like electricity. :)
So far been nice for taking photos of sparks. http://oms.wmhost.com/pics/30kV/overclocked_1.jpg
Wed Apr 01 2009, 05:40PM
Better filtering will indeed increase power throughput and give you thicker arcs. It seems it can also reduce flyback heating. The driver looks good :). I cannot view the video *murmurs something about windows media player*.
