  • Guests: 48
measuring TC output voltage
some3
Tue Mar 24 2009, 12:54PM Print
some3 Registered Member #1887 Joined: Sun Dec 28 2008, 02:19PM
How can i build a Hv probe to mesur the output voltage of the TC.
tnx
lhl_henrylui
Tue Mar 24 2009, 01:09PM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
please see this thread: Link2
see aonomus's post
Tue Mar 24 2009, 01:27PM
Measuring the output of a Tesla coil is difficult, for three reasons:
1) The voltage is very high. Coils I've built ranged from 180kV (for a small tabletop coil) to 600kV for a large coil that put out 2 meter sparks.
2) The frequency is high, needing a properly compensated probe.
3) Any capacitance added to the Tesla coil will knock it out of tune. Therefore DanMcCauley's design would be useless with its large compensating caps.
Here are some methods I've used:
1) Reduce the break rate of the coil to one bang per second or less, and measure the distance it can spark. Use published tables, suitable for the spark gap geometry you use, to convert the distance to voltage. (This only gives a rough estimate, and goes totally wrong at high break rates.)
2) Find the inductance and resonant frequency of the secondary, then measure secondary base current with a scope, and use Ohm's law: V=I*XL. You're using the secondary as its own HV probe.
3) Connect up a HV probe, and retune the coil so it's in tune with the probe in circuit.
4) Simulate your coil using LTSpice or whatever, and read off the voltage from that.
LithiumLord
Tue Mar 24 2009, 03:22PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
5) ( ;) ) Make an antenna probe, theoretically/practically determine it's capacitive divider ratio - and here you go ;)
