  • Guests: 52
Slow MOSFETs
ScotchTapeLord
Sat Mar 21 2009, 07:29PM Print
EDIT: soft switching is not an option, but I'm still curious as to the responses to my question.
Hello. I seem to have destroyed my IRF740's and all I have left are these much slower (but more durable) FETs. I don't know whether I can operate these at the frequencies I need. Should I soft switch them? What is the advantage of hard-switching over soft switching? Maybe I should just order new FETs...
LithiumLord
Sat Mar 21 2009, 09:16PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Not enough data ;) What are your "much slower" FETs exactly? What frequency are you going to run them at? What is the amount of the estimated forward and reverse power levels?
There is no ;) - soft-switching provides way less switching loss.
ScotchTapeLord
Sun Mar 22 2009, 12:53AM
I tested it and they were switching at up to a few 100kHz. That's what my oscilloscope revealed anyway. Although when I tried connecting the primary, very little current flowed, though the oscilloscope showed a wonderful waveform. I also noticed that the voltage across my pseudo switch caps would drop... What is wrong with my half bridge? I will get more information in the morning... Just wondering if anyone has experience with overcoming this problem.
Sun Mar 22 2009, 01:44AM
A partnumber would help, please do not ask questions without giving all the information you have.
ScotchTapeLord
Sun Mar 22 2009, 02:01AM
I was having the current problem with IRF740s too. I believe the problem might be the capacitors, which are just 1 uF nonpolarized radioshack pieces of junk. What type of capacitor/capacitance is recommended for a frequency of about 300kHz, running from 170 (fullwave rectified mains). Current draw can be up to 10 amps. I ran the driver as low as a few kHz and still had the problem. When I test the voltage across the a half bridge cap or the voltage in series with the primary coil, it starts high and drops to zero. I don't think the protection diodes are part of the problem, but I am using MUR1560s in antiparallel to protect the internal diode. I am also using the same type of diode in "antiseries" with the built in mosfet diode in place of schottkys, until they arrive... Could that be the problem? I don't see how that would drain the capacitors, though...
LithiumLord
Sun Mar 22 2009, 12:28PM
Woah. All needed here is your schematic with all the part numbers included. Unless it's done there is no way anyone could help you at all.
