  • Guests: 48
Planning on winding own flybacks
Killa-X
Sat Mar 21 2009, 07:09AM Print
I have a flyback core and done tests with it, my first was simply old wire, and boxing tape. That didn't last too long. My 2nd test, was just coil and 4 layers of overhead sheets between each layer.
Here's my question.
can I just take wood varnish aka polyurathane and cover each layer with it?
About how many layers of this varnish should be applied?
is 4 overhead sheet-thick between each layer good enough to use?
rp181
Sat Mar 21 2009, 04:06PM
If you can get some, teflon would work well. Make sure you keep space between the edge of the winding to the edge of the layer insulation to prevent arcing. Varnish probably wont work, unless you used lots of layers.
I have had it work well by using plumbing teflon tape, wrapping several layers, and putting paper ove that, for oil and a good winding surface.
teslacoolguy
Sat Mar 21 2009, 04:32PM
insulate the layers in paper or something similar and after you wind it, submerge it in oil and the paper will suck it up preventing any internal air bubbles.
Sat Mar 21 2009, 05:20PM
teslacoolguy wrote ...
Ah yes, i did forget about that. Apparently it is good for HF AC insulation. But the question is how thick of paper?
Killa-X
Sun Mar 22 2009, 01:07AM
I do own Teflon plumbers tape.. Your saying that I would wind my coil first layer, Cover it with teflon tape, then put a few layers of overhead paper it on, and repeat? Either way I got to oil it.. was hoping a way to avoid that since all I own is vegi oil :(
Sun Mar 22 2009, 08:33PM
You can use silicone aquarium adheasive instead of oil, see Link2
Plasma Lover
Mon Mar 23 2009, 07:07AM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
I've been thinking of winding my own for a while, but I've decided that I'll get the power supply running reliably first. Anyways, my idea was to use polyurethane varnish in between each layer, letting it dry over each layer so it would hold itself together in the spiral (and helix) that would be the winding pattern. This would keep it from unraveling and, since it would dry before winding the next layer, it would be air-tight. Being air-tight is definitely a desirable trait in this case.... the polyurethane would, undoubtedly, soak into all the cracks. Another option is to heat up the container of polyurethane to the point that it starts gassing off immensely, and then submerge the wound core in it. This would saturate the windings (and not the core! ><), keeping them from being hurt by high-voltages. The main problem is that this would end up having a solid-ended flyback that can't have the secondary removed. If the operation doesn't work properly and your LOPT fries, bye-bye core...unless you want to dissolve the poly...
Just my fifteen cents. I need the other eighty-five to buy myself a new core...
Anyways, Good luck, Killa-X,
Christopher
RickR
Mon Mar 23 2009, 03:34PM
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
I've heard of people saturating kraft (or some other porous) paper in polyurethane varnish and wrapping each successive layer of the coil in strips of the paper. That way you get inter-layer insulation plus a minimum guaranteed separation distance between layers.
Rick
