  • Guests: 66
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
New member introduction with a SGTC!
Jason
Wed Mar 18 2009, 09:39PM Print
Jason Registered Member #896 Joined: Sun Jul 15 2007, 01:56AM
I'm the new guy here so I thought I would introduce myself and share a project at the same time.
My Name is Jason and I am from New York. It's nice to meet a group of people with similar interests!
I have been into electronics and computers for most of my life. I hope to build a SSTC this summer.
Here is my first SGTC I built (now almost 10 years ago!)
It is powered via a 15Kv 60mA NST.
The Secondary is 10" diameter and approx 1900 turns.
The capacitor was homemade constructed out of rolled poly sheeting and aluminum flashing in a mineral oil bath... Unfortunately the capacitor only lasted for a few minutes of runtime before it suffered from internal flash-over. I may build a MMC and try to resurrect this coil!
1237408846 896 FT1630 Jptesla1
1237408846 896 FT1630 Jptesla2
1237408846 896 FT1630 Jptesla3
1237408846 896 FT1630 Jptesla4
Sorry for the poor quality scanned photos!
Corey
Mon Jun 08 2009, 05:17AM
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
looks good I soon will be building a sgtc of similar specs, should be fun to see how it turns out.
Hazmatt_(The Underdog)
Tue Jun 09 2009, 04:19AM
That cap has to be rolled up TIGHT! or its not going to work.
StevenCaton
Tue Jun 09 2009, 04:50AM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Jason, you either need to make that primary coil really conical, or raise your secondary up quite a bit, or do both. Otherwise your secondary will arc to your primary almost immediately.
Did you run it like that in the past?
