  • Guests: 45
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Blue Argon-Laser ALC-60X
kilovolt
Wed Mar 18 2009, 06:49PM Print
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Dear All wink
Just wanted to show a project which i did about a year ago. There was a cheap offering from a german laser company for a multiline-argon laser head ALC-60X used and without any warranty. The unit came without power supply, so i had to build one myself. It is a linear circuit for 110V / 10A current regulated. In addition there are a 3V/25A supply for the heater and a 300V supply for the igniter-circuit inside the unit. Building the power supply took me about 1 week.
The laser unit itself:
Argonlaser1
The power supply, almost finished (but without cooling fans):
Argonlaser2
First test-run of the power supply:
Argonlaser3
Beam of the argonlaser and an old HeNe:
Argonlaser4
Argon beam deflected by 2 prism:
Argonlaser5
Argonlaser6
Argonlaser-Beam splitted in all lines with a grating:
Argonlaser8
Beam going through some water-glasses:
Argonlaser9
Greets kilovolt wink
Wed Mar 18 2009, 06:59PM
Holy bejesus thats awesome!
You should post more details on the power supply, it looks like a pretty impressive project.
Do you know what kind of output power you are getting?
I am glad you got it working smile May it give you many hours of turquoise awesome.
kilovolt
Wed Mar 18 2009, 07:38PM
Hello ... smile
Thank you very much for your friendly feedback wink
Unfortunately, i have no power-level-meter. But due to the fact, that there are 9 lines at about 8.5A tube-current i think it will be at least around 100mW (not sure!).
Thanks again wink but I have to say that this is a rather simple circuit. It is mainly an operational amplifier for current control and a power stage with 12 bipolar transistors for handling the tube current. The supply for the heater is a toroidal transformer with a selfmade secondary winding.
Some of the main parts of the supply:
Material for the power stage, transistors, heat sinks and caps:
Materialf
The control board with operational amplifier and shunt for measuring the tube current:
Regulationcircuitop
power-board for 110V-supply:
Powercircuit110v
First setup without housing: wink
Firstsetup
Overview of the finished power supply. Unfortunately i have no picture form the board in the middle which is for generating the 300V for the ignitor:
Supplyoverview
Opened laser unit (it's almost the same as the omnichrome 532):
Openedlaserunit
Thank you smile
EDIT: For those of you who would like to build this power supply (works also for other Argonlasers in the same power range), I'll post here the schematics. They are not mine, but i'm allowed to post them here...
In the second schematic there must be 12 transistor stages in parallel, shown are just three of them.
regards
kilovolt wink
kilovolt
Thu Mar 19 2009, 08:24PM
Sorry for double-post smile
An interesting experiment one could do with a multiline argonlaser is the extending of the resonator for selecting specific lines. This can be done with an additional, external mirror. In my case it was a green coated mirror from a defective green HeNe laser. The green laser line has been amplified between laser unit and mirror, while after the mirror only deep blue lines are visible.
Extres1
Extres2
best regards
kilovolt wink
kilovolt
Thu Apr 02 2009, 07:54PM
Just had a little argon-laser-session:
Dsc00799d
Dsc00802j
Dsc00793ojl
Dsc00806j
Dsc00790n
Sorry, I'm too lazy to resize the pictures again... wink
Best regards
kilovolt smile
