  • Guests: 53
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Large Can High Voltage Electrolytics RoHS Compliant
Tue Mar 17 2009, 01:26AM Print
I am able to supply brand new BHC large can high voltage RoHS electrolytics to UK addresses only at a fraction (generally about 25%) of the cost charged by Farnell and RS.
Largest size currently available 15000uF 450VDC.
Most types are bottom bolt, screw terminal units, but some smaller units (e.g. 1000uF 400VDC) are snap in types.
Further discounts can be applied to whole cases. Case sizes range from eight units to the case for larger capacitors (e.g. 4100uF 450VDC) to 36 units per case for smaller types (e.g. 1400uF 385VDC).
All are brand new current BHC stock with manufacturers serial numbers and RoHS compliance.
Interested parties to send private message.
