  • Guests: 51
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Buying stuff.
Sun Mar 15 2009, 10:47PM Print
I need a few of the necessities for coiling/general electronics.
I can either give payment, or a trade.
I need a good oscilloscope, basically i require 100mhz or higher, and dual channel. I am looking for a used one that works, because i have little money. I could trade a 50KVA 7.6kv pig, but keep in mind i am 15 (i know it works, just letting you know age ahead of time) and that it was gotten from the side of the road after a hurricane which knocked it down. While dragging it home, i passed by a few people working on power lines (this was right after the hurricane, some power was still out or was often going back out from branches and the like) and nobody said anything. It is not dented of noticibly damaged. It would however be pickup only, of course as it weighs 629 pounds. I will help load it into a truck (i drug it here on a dolly, but the wheels exploded, so a dolly would be required). Give me pictures and what ever else, and we can make a deal if you want money or other items.
I would like any spare mosfets that anyone may have. I would like it if you just have a bunch of unused mosfets you need to get rid of, for something cheap tongue. I need around 400-500 volts and 20 amps or more. I can once again trade stuff or give money. For a bunch, i could trade the pig :P.
A few thousand feet of 22-20 gauge magnet wire. I need around 2000 feet or so (to make sure :P) for a 6.5 inch by 34 inch secondary.
What i have to trade...:
*the 50kva 7620 volt pig (more specs if interested) pickup only
*A small 6kv 30ma nst, and the 8 CDE caps required for LTR of abour 18.75-20nf and 16kv iirc
*74(mostly 74ls) series IC's (i have around 200 of them)
*small audio tubes (nobody usually has a use for these :P)
*2 3900uf 400vdc capacitors, both together would be 624 joules, computer grade, screw terminal.
*2 80vdc 100vdc surge 22000uf capacitors.
*a bunch of smaller heatsinks, one fairly large, and two that are about 4 or 5 inches wide and about a foot long, and around 8 small heatsinks, identical.
*Some rather pointless 24 gauge tinned uninsulated wire
I have more misc components, if you need something just ask and i will look. Since most of this stuff is useless, i will probably end up paying with money. As some have seen, there have been quite a few other posts asking to sell stuff :P.
Oh, and i am not excepting any more freebies :P. Have had too many, which i do appreciate.
Thanks!
