  • Guests: 69
Very old Flyback
LoFi Ninja
Fri Mar 13 2009, 02:59PM Print
LoFi Ninja Registered Member #2024 Joined: Fri Mar 13 2009, 02:08PM
Hello..
I've got this old flyback
3350810935 19a2bd65df M
3351636780 F5116c561a M
So ofcause I want to play with it!
In the second pic you can see two coils.. Whats the very small one ? feedback?
Anyways I wish to use this simple driver I found on SIXMHZ site http://www.angelfire.com/80s/sixmhz/flyback.html Will it do?
Fri Mar 13 2009, 03:37PM
It will work, yes. But it will be very low power and lots of heat. The ZVS is however not suggested to beginners of high voltage, they can likely kill. The 555 flyback driver is something i would suggest, to keep heat down and get higher efficiency. Also, if you make it well and use higher input voltage, you can get very high voltage. I have had sparks jump 8 or so inches!
With the 555 driver, you can also make it sing, by simply putting an audio signal into pin 5. More on that if you get one built (on my spare time, i like to pretend i am a news reporter, or someone that matters tongue)
Fri Mar 13 2009, 03:59PM
You are lucky to have found an old AC Line Output Transformer (US: "flyback") which does not have rectifiers built into the case, and so is much more valuable to the experimenter.
The small inductance wound on the core in your second picture is not a feedback winding. It is the filament supply for the rectifier valve (US: "tube") that would have provided (typically) 6.3V @ 100mA or so, depending on the particular rectifier valve designed for.
The open frame construction of this kind of LOPT makes it very easy for you to wind your own primary, as many on this site prefer to do.
A lucky find! smile
LoFi Ninja
Fri Mar 13 2009, 04:18PM
Arcstarter: Ok I will go for a 555 driver.. I surely want it to sing ! I guess some 8-bit chiptunes fits nicely hehe..
Harry: Yes I know it's a nice one.. I've tried earlier with the newer black pottet ones and never made it work. And Have read many times how you would want an old one with a bare primary, and no rectifiers.. I have actualy had this guy for like a year two in a drawer, because I kind of abandoned HV because I never could get stuff to work, but I still could't throw it.. I guess I knew I wanted to try again some time haha..
Anyways, so I can just remove the small coil underneath the primary ?
PS: Why do people want to wind primary them selves? For fine tuning?
PPS: I also have a cascade that I found with this flyback.. So in theory I should be able to get around 25 KV yes?
Fri Mar 13 2009, 05:16PM
LoFi Ninja wrote ...
Yes - the filament heater winding is unlikely to be of use to you.
The LOPT's own primary coil is designed (from memory) to work at about 115V, and has a good number of turns on it. Some experimenters do use the original primary, but most prefer to wind a primary with far fewer turns on the core, to drive it with NPN bipolar transistors like 2N3055, or the more fashionable power mosfets with very low on resistances.
Yes, that sounds possible.
Littlew
Fri Mar 13 2009, 06:29PM
Littlew Registered Member #1448 Joined: Sat Apr 19 2008, 01:16PM
put something to compare sizes(box of matches etc)
i thought it is rare 25kV flyback(my opinion is based on construction of flyback)
LoFi Ninja
Fri Mar 13 2009, 07:02PM
No noo.. Usually flybacks are what ? 8 kV? And then the cascade multiplys by 4 so thats 32 kV but that's aiming really high.. So 25 kV..
LoFi Ninja
Fri Mar 13 2009, 08:56PM
Would it be a problem replacing the MOSFETwith a IRF634A in this schema ?Allthou the RDS(ON) is 0,45 ohm ? and not as low as 0,1 ohm..
ET Flyback Basic
Fri Mar 13 2009, 11:28PM
Perhaps you should put a buffer between the timer and the gate.
I would be concerned that without any protection, that a 200V mosfet may not long withstand inductive kick-back spikes.
You will find plenty of comment on these subjects if you search the forum for them.
Sat Mar 14 2009, 09:18AM
With 12 volts he will be absolutely fine with a 200V FET.
The problem is that this circuit heats a lot, and if you use a bipolar transistor it heats even more. angry
An improvement is my "quasi resonant" mod. (search forum)
